Author Topic: 45 mitre failures  (Read 10121 times)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
45 mitre failures
« on: February 06, 2008, 01:27:15 am »
I have Ryobi 10 inch mitre saw that for the life of me I have never been successful at cutting consecutive 45 degree corner pieces to make a nice squared frame.
I have a large piece I am trying to make a frame for and have failed miserably again at getting it right.
I end up having to bondo and sand the corners so as to not end up with gaps.
It's always very close but slightly off.
It shouldn't be this hard, any suggestions other than throwing this saw out and starting over with something else?
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
Re: 45 mitre failures
« Reply #1 on: February 06, 2008, 02:01:53 am »
A couple of things...
Have you aligned the saw, that is checked that 90 is actually 90 and 45 is 45..
Also when cutting do you clamp the wood to the guide to make sure it does not move...
If you are just holding it in place the saw will tend to drag the wood a little which will throw the angle off.
Having said that you also have to be sure the base locks in the same place every time, I know on mine there is a little bit of play around the stops, so to be really accurate I need to check the angle of the blade on every cut. If the joint is going to be out of sight I don't bother that much and just do what you do and fill the gaps..
On small stuff like say a picture frame I will always cut by hand using a mitre box and a fine toothed saw, taking it slow the results are normally good...
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
« Reply #2 on: February 06, 2008, 11:54:54 am »
As Orclords suggest, if you want perfect 45-degree cuts you probably need to adjust the setup on your saw. Mine was close out of the box, but still off by about 0.5-degrees. Which is all it takes to throw off the alignment of a frame. You'll need a good 45-degree reference if you want the angle to be perfect. I use my Starrett combination square for this purpose. If you don't want to spend the money for a Starrett, I'd suggest buying a machinist's 45/45/90 setup block. Enco has theirs on sale for $10 (part# 418-4810). Be sure to check both the 45-degree and 90-degree stops on your saw! Just because one is correct doesn't mean the other one is...
Also, keep in mind that in order to have a perfect frame not only do the miter angles have to be correct but the lengths of the opposing sides also have to match exactly. You can cut eight perfect 45-degree angles, but if the lengths are off by even a few tenths of an inch your frame won't be perfect. You'll want to use some sort of stop block to make sure that the opposing sides are cut to the same length. Clamping the piece to the saw table, as Orclord suggests, is also a good idea.
Finally, you want to make use of complementary angles when you're cutting the wood. If you make a cut in a piece of wood and you mate the pieces from either side of the saw blade, you're guaranteed to get a 90-degree corner. Say your 45-degree miter stop is off by 1 degree. So it'll cut a 44-degree miter... but the offcut is guaranteed to have a 46-degree miter. Put the two pieces together and you end up with a 90-degree corner (44+46=90). Make use of this fact when designing your cuts. Ideally, you'd start your frame project with two identical length pieces of wood and only make four cuts with the saw. If you're making eight cuts, instead of four, there's much more opportunity for error to creep into the project.
Finally, realize that even if you do everything correct that errors may still creep into the project. That's why it's always a good idea to own a high-quality (Veritas, Lie-Nielsen) low-angle block plane, know how to sharpen it, and also build a miter shooting board so you can shave the ends of the miter cuts until they're perfect.
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
« Reply #3 on: February 06, 2008, 09:37:26 pm »
Not really.  If you want a 90-degree angle from miters, you need to have your saw aligned to 45 degrees.  In your example, you're not really mating a 44 and a 46 to get to 90, you're mating a 44 with another 44 to only get to 88 degrees.  Think about an extreme case where your saw was misaligned by not 1 degree, but 15, so when you think you're cutting at a 45-degree angle, it's actually 30.  You're going to cut that miter and you're going to end up with two trapezoidal pieces of wood (assuming square ends to start) that have angles that go 90/90/30/150.  If you butt the 30 up against the 150, you've just recreated the original piece of wood.  If you flip one over, now the 30s are touching on the outside corner and the 150s are touching on the inside, and you get a 60-degree corner, not a 90-degree corner.  You end up with more of a V shape than a right angle.
sstorkel
« Reply #4 on: February 07, 2008, 02:56:44 am »
Yeah, you're right. I had a brain fart: the complementary angle principle only works if you have a jig designed to take advantage of it. With a standard miter saw, you're going to be S.O.L. if the blade isn't setup at exactly 45-degrees to the fence...
  • Last login:Today at 03:23:15 pm
« Reply #5 on: February 07, 2008, 10:24:49 am »
Any tips for making miters with a table saw?  I'm about to build something a little crazy (a control panel box mitered on ALL sides including the bottom) using cabinet grade plywood.  There's also a 5 degree slope downward for the top panel so I have to factor that in too.  Basically, there won't be a single 90 degree cut on any edge of the 5 pieces I'm going to be using for the control panel base...  I also have a compound mitre saw but that can only cut lengths up to 12" which will be fine for the corners of the box but not for the bottom.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #6 on: February 07, 2008, 10:59:23 am »
yep...buy this...!
http://www.newwoodworker.com/reviews/incra1000servu.html
i made a poster frame with my table saw and this miter gauge...
the hardest part would be getting the lengths of each piece exact...so you have to be a patient perfectionist...i crept up on my cut line with a few passes for each cut...
sstorkel
« Reply #7 on: February 07, 2008, 01:10:32 pm »
Good luck with that... it's a task that even experience woodworkers struggle with! Here are some random suggestions:
1) Don't expect everything to fit right the first time. When making a box like this, there is a lot of opportunity for error. And even the slightest error may mean that the corners don't mate perfectly. I'd plan to start out making test cuts on scrap wood rather than your expensive cabinet-grade plywood. Heck, I'd probably go so far as to try to make a small (6") box with mitered joints before I attempted the control panel.
2) Minimize the number of setups. Every time you move the fence to adjust the saw blade, there's the possibility that your new setting won't be quite the same as the last one (or the same as it should). If you find a setting that works, make all the cuts that require it before changing the setup again.
3) Invest in some good measuring tools. Small errors can have a big impact on how well the pieces fit together! I think you'll have to be within 1/32" on the lengths in order to have everything fit precisely. Angles probably have to be accurate to 0.5 degrees... maybe 0.1.
4) Don't trust your saw's measurements. Don't trust the measuring tape on your fence, the angle settings on your miter gauge, or the angles on the blade tilt. Measure everything to ensure that it is precise. If you have accurate setup blocks (e.g. a test piece that is the right length, or the 45-degree angle on your Starrett combination square) use them during setup, not the markings on your saw.
5) Finally... cheat! This is a time-honored tradition among woodworkers. I've, hopefully, attached a picture of two possibilities. The one on the left shows a mitered corner where the angle has been cut at 43-degrees rather than 45 degrees. As you can see, the pieces meet at the outside edge, which is all that is necessary for the joint to look good. If the pieces had been beveled at an angle greater than 45 degrees, they'd been on the inside and there'd be a gap at the outside edge.
The second picture, on the right, shows what happens if the top is cut slightly oversize. This would look like junk! At least until you throw a flush trim bit in your router and trim the top to be an exact fit to the base (e.g. along the red line)! The added advantage is that the edges of the top will be slightly thicker and so might resist dents and damage better than a perfect miter. Inevitably, you'll probably end up with some variations in thickness along the top. Most likely, people won't notice. If you're concerned, you can probably cover it up during the painting and finish process.
Finally, you may need to add glue blocks to support the horizontal piece shown in each of the pictures. You can see that there isn't a whole lot of contact between the horizontal and vertical pieces, due to the inaccurate miters and sizing. A 1x2 glued and screwed to the vertical piece will take care of this nicely...
« Reply #8 on: February 07, 2008, 02:21:39 pm »
Thanks for the tips.  I plan on cutting the bottom panel first and making the 4 miters to get it to size.  Then I'll make the side pieces all oversized and use the radial saw and stop blocks to ensure they are exactly the right length.  The part I'm concerned about is running the long pieces through the blade on the tablesaw.  Even when I'm trying to make a straight cut there seems to be a little bit of drift (1/32"?).  I check, recheck, lock the fence down and run it through and I still seem to get the drift - I don't think the lock down of the fence is tight enough but I don't know what to do - I even add a clamp to try and keep it in place...
Orclord
« Reply #9 on: February 07, 2008, 03:47:55 pm »
Fences on cheap table saws are crap.....
iirc.... it's been a while though.....What I did with the father in laws was use a piece of 2x2 behind the fence...
Have one of these at both ends... http://www.daviddarling.info/encyclopedia/R/AE_rafter_angle_square.html to get it square and clamp the 2x2 down as hard as I possibly could......
Then you will probably find the blade is running out of true and have to adjust that......
Precision cuts with any machine us normal people can afford are a PITA........
sstorkel
« Reply #10 on: February 07, 2008, 05:05:02 pm »
Is it the fence moving around? Or is it the wood drifting away from the fence? You can always use featherboards to keep the wood tight against the fence. You should also check the distance between the fence and the blade. Be sure to check both at the front of the blade and the back. Some saws are setup so that the fence angles away from the blade slightly, in order to help prevent the wood from getting pinched between the back of the blade and the fence.
You might take a look at this link where John Lucas builds a mitered cube using a Festool circular saw and guide rails. I haven't looked at the whole thing, but there might be some useful ideas there. He must be doing something right if he can make a cube that works using only a circular saw and a guide rail!
« Reply #11 on: February 07, 2008, 05:20:10 pm »
Great link.  I'll be reading that in detail.  The wood is drifting away from the fence.  I do check the distance at the front and back of the blade which is why I'm having a hard time figuring out what is going wrong.  Also, I'm not sure the surface of the tablesaw is slick enough but I don't know what to do about it - I don't want to stain/ruin any wood with randome chemicals or something.  Would the featherboard keeping the wood tight against the table solve this?  I can't even begin to imagine using one to keep the wood tight to the fence...
Orclord
« Reply #12 on: February 07, 2008, 05:44:19 pm »
Not being funny...Just in case it's sthg I don't know...But could you explain that statement...
If the fence angles away, then how in hell are you going to get a true cut....
And if they do angle away, surely that would cause it to bind in the first place...
« Last Edit: February 07, 2008, 05:53:03 pm by Orclord »
sstorkel
« Reply #13 on: February 07, 2008, 06:50:28 pm »
It's not like there's a huge angle. I think the figure I've typically heard is that the back of the fence is 1/32" further from the blade than the front of the fence is.
The theory is that the front of the blade is where the cutting happens, so that's where accuracy counts. Nothing really happens at the back of the blade... except, perhaps, the start of a nasty kick-back accident. So if you angle the fence away from the blade by an extra 1/32" (or maybe it's 1/16"?) at the back, you have a little additional "wiggle room" to prevent the wood from being pinched. Proponents of this theory claim that it is especially useful when cutting "reaction wood" that has a lot of internal stresses which will be released as the blade starts to cut through the wood. They might also tell you that even if your cuts are a bit off that it won't be enough to matter.
I, personally, would set a saw up so that the fence is parallel to the blade. But I also make cuts with the blade guard and splitter in place to help prevent kickback.
sstorkel
« Reply #14 on: February 07, 2008, 07:02:50 pm »
If the wood coming away from the fence before the front edge of the blade? Or after it passes the front of the blade? If the wood is coming away from the fence after it passes the front of the blade and the fence is parallel to the blade... I'm not sure what to tell you. The only thing I can think of is that there might be something wrong with your sawing technique, though I'm not sure what it would be. I would, however be somewhat frightened! Having the wood angle toward the back of the blade generally isn't a good thing!
The traditional way to decrease friction on a saw table is to use wax, typically beeswax or some other form of paste wax. There are also chemical sprays that you can use. Topcote is the only product that comes to mind immediately. If you go the chemical route, make sure that whatever you use doesn't contain silicon because that can introduce problems at finishing time.
If you wanted to use a featherboard, you'd place it on the table so that it pushes the wood against the fence in front of the blade. Here's a picture.
« Reply #15 on: February 09, 2008, 06:32:42 pm »
Based on all the trouble I had today (as evidenced by some burn marks), I need to get that featherboard.  After spending about 5 hours in my workshop (if you can call it that) I came up with the thing in the attached picture.  I amazed myself with how accurate everything came out.  It is totally square and everything fits very snugly.
How should I join everything (it's dry fitted right now)?  Is glue enough?  Biscuits?  How do I get clamping pressure on the "lid"?  It isn't shown but I also cut a panel mitered on all 4 sides which sits right on top making it kind of look like one block of wood.  Also, is there anything I can do to the seams to make them seamless?  It's seriously within 1/32" or maybe even less but you can still see a slight line.  I plan on staining and sealing with poly.... will that do it or is there another trick?
THANKS!!!   :cheers:
fixedpigs
« Reply #16 on: February 09, 2008, 07:15:17 pm »
nicely done... :applaud:
just glue and some good clamping pressure with will be provide solid joints...
of course...that's considering to two flush surfaces...
it _might_ be problematic if you have a gap from your mitered cuts...
(edited because i can't seem to use the correct words...!)
« Last Edit: February 09, 2008, 07:44:48 pm by fixedpigs »
sstorkel
« Reply #17 on: February 09, 2008, 07:26:29 pm »
just glue and some good clamping pressure with be provide solid joints...
 :laugh2: Clearly, you've never applied clamps to a corner joined with 45-degree miters. It's a mistake you only make once...
fixedpigs
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
sstorkel
« Reply #20 on: February 09, 2008, 08:10:00 pm »
Nice work!
Joining mitered corners is a matter of some debate. If you just apply glue and try to throw some regular bar clamps on the piece, the miters will slip right past each other and the whole thing will collapse! There are a couple of alternatives that depend on what tools you have available. I'll focus just on joining the sides of the box together. Once you've done that, the rest is easy. Here are some options:
1) If you've got tight-fitting miters, and it sounds like you do, the cheapest alternative is to use wood glue and packing tape. The basic idea here is that you dry-fit the joints, then tape them together on the outside with clear packing tape (or any other tape that's strong and won't leave nasty residue behind when removed). The tape acts like a hinge to prevent the corners from falling apart. Tape 3 of the 4 corners. Then you sort of "unroll" the piece, spread glue on all of the joints, fold it back up, and tape across the fourth corner.
I've done this with small, solid wood boxes and found it to work well for that purpose. The tape doesn't provide a whole lot of clamping pressure, so it may or may not be possible to pull a gap together. And you need to be pretty careful to make sure you don't pull the whole thing out of square once you apply the glue.
2) You can use special corner clamps to hold the project together. I own several of the cheaper versions:
http://www.woodcraft.com/family.aspx?FamilyID=4250
http://www.woodcraft.com/family.aspx?FamilyID=4384
Which really aren't worth the money. They're not necessarily an exact 90-degree angle, don't provide much clamping force, and have never given me great results. I've used the heavier duty version of this Bessy corner clamp:
http://www.woodcraft.com/family.aspx?FamilyID=4249
And it works pretty well, but the price is pretty absurd. I also own a bunch of these 3D squares (which I bought directly from the manufacturer at a woodworking show for about half Woodcraft's price):
http://www.woodcraft.com/family.aspx?FamilyID=4484
These work very well. The configuration that the Woodcraft picture shows is an especially good one: you clamp a couple of pieces of scrap wood to one square, then insert the piece you want to glue, the put another square on the inside of those pieces and pull the whole thing together with clamps. It's great for flat pieces, but probably not so useful in your situation.
I've heard good things about the various forms of miter spring clamps:
http://www.woodcraft.com/family.aspx?FamilyID=5151
http://www.woodcraft.com/family.aspx?FamilyID=3860
But haven't tried them. They make small holes in the wood, which I've never been a fan of.
3) Mechanical reinforcement of the joint isn't a bad idea. I've used pocket screws and biscuits in this situation. I've always found that getting biscuits properly aligned on 45-degree miter joints is a bit of a hit or miss proposition. Just when you think everything is right, something will move a little bit and your biscuit slot will end up 1/32" or more from where it really should be. Pocket screws are a better bet, in my experience. You'll make the holes on the inside of the piece, so they won't be seen. What I like to do is make a perfect 90-degree corner to use as a jig. I'll drill the pocket screw holes in one of the sides, apply glue to the wood, push the two sides against the jig, check the fit, and then screw everything together. In theory, pocket screws may also be able to pull a corner together if the fit isn't quite tight.
4) The final option, which can be a bit tricky, is to use bar clamps. I know: it can't be done. The trick is to take scrap wood and use it to support the box while you're using the clamps. I'd cut a piece for each end and a couple of pieces to run along the length. You can use any old wood, though it helps if it's straight. The idea is to be able to pull the corners tight using the bar clamps, but have the scrap pieces resting inside the box prevent it from collapsing. If that makes any sense...
Finally, I'll suggest that it's probably more important to get the miter joints to close up than to have each corner be absolutely, square. If your gaps are 1/32" or less, you're close enough. It's not going to matter if you have to squeeze the joint from a perfect 90-degrees down to 89.75-degrees. It will be very noticeable if there's a gap at any corner, however.
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #21 on: February 09, 2008, 10:44:59 pm »
Anyone ever try this little gadget?:
http://www.rockler.com/product.cfm?page=17206
I've always thought it's a cool idea, but I've never picked one up since I know I wouldn't use it very often (my blade is almost always at 90 degrees). It might be just what you need though if you really can't seem to get your blade close enough.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
fixedpigs
« Reply #22 on: February 09, 2008, 11:25:07 pm »
i have that...!
it is waaaay badass...!
i got it free with my wixey saw fence digital readout...
i think normally it's like forty bucks or something...absolutely worth it... :applaud: :applaud:
sstorkel
« Reply #23 on: February 10, 2008, 03:28:53 am »
I'm skeptical that these devices are as accurate as they claim to be. If you buy one, make sure that is has a programmable zero set point. Personally,  I'd be more inclined to trust a machinist's setup block than something that tries to use digital circuits to measure the direction of gravity...
« Reply #24 on: February 10, 2008, 09:42:53 am »
Thanks for all of the tips and ideas!
What about a band clamp?  I put one on there and it seems to be holding everything together quite nice.  I'm thinking about buying another one so I can wrap both the top and bottom instead of just one band around the middle.  I really would like to use biscuits or something to reinforce the joint but I'm afraid it's one more thing that could throw things out of alignment.  I'm going to practice a bit with some scrap and see how tough it will be...
nuka1195
« Reply #25 on: February 10, 2008, 10:26:59 am »
if you do use biscuits, make sure you either use smaller ones #10 and/or set it closer to the inside thicker part, so you don't cut thru your piece.
You can also mount the biscuit jointer in a clamp on a bench, if you have a nice wooden clamp. Sometimes it's easier that way.
fixedpigs
« Reply #26 on: February 10, 2008, 11:55:09 am »
you obviously haven't used this thing in person...if you have...you'd understand how awesome it is...
you can calibrate it from any surface at any angle to go from...calibrate it on your table top...stick it on the blade(the device is magnetic)...then adjust the blade if necessary...simple...easy...and absolutely accurate...!
sstorkel
« Reply #27 on: February 10, 2008, 12:50:11 pm »
How do you know it's accurate? Because it has an LCD?
If it doesn't come with a NIST calibration certificate, or a certified calibration mechanism (e.g. some sort of gage block) then there's very little chance it is accurate to the tenth of a degree that it claims. If it were, I suspect my machinist friends wouldn't be spending hundreds of dollars on measuring tools and tens or hundreds of thousands on Computer Measuring Machines (CMMs)...
fixedpigs
« Reply #28 on: February 10, 2008, 01:21:26 pm »
haha sstorkel...
there you go assuming again... ::)
i have checked the accuracy of this thing against a protractor & 90deg machinist's block...that how i _know_ it's accurate...
go ahead and keep being skeptical...trash-talking something you have no personal experience with...
perhaps you should take your own advice...
http://forum.arcadecontrols.com/index.php?topic=75556.msg786717#msg786717
« Reply #29 on: February 10, 2008, 04:29:43 pm »
OK, back to the important stuff.  Biscuits and band clamps it is!  The last pic kind of shows how close the corners and everything are.  This is a dry fit and everything seems snug.  I will be using more clamps in the final glue-up.  Not bad...
Tahnok
    • Table Arcades
« Reply #30 on: February 10, 2008, 05:15:06 pm »
Well, after reading your review, fixed, and the ones on Rockler, I have a strange feeling one of those digital gauges may make it's way into my cart next time I place an order with Rockler. There's 31 reviews on that page, all positive, not one of them claiming that it's inaccurate. It may not be up the standard required by machinists, but I'm sure it's fine for this kind of work.
sstorkel
« Reply #31 on: February 10, 2008, 08:37:57 pm »
Sweet! As stated previously, I was concerned that it didn't have the claimed 0.1 degree accuracy. I had assumed that they might only be accurate to 1.0 degrees, while selling for 2-3X more than a traditional protractor with the same accuracy.
Now I can understand why you got so bent out of shape! I simply didn't realize you owned a vernier protractor capable of verifying measurements down to 0.1 degrees! Did you buy it yourself? Or inherit it? What's the discrimination? 5 minutes (a.k.a 1/12th degree)? I've been looking for a decent one on eBay, but prices seem to be running $100-150+ for the brands I recognize. That's a lot more affordable than the $300-400 it would cost to buy a new one from Mitutoyo, Starrett, or Brown&Sharpe but still out of my budget...
