Author Topic: WG U3100 - picture shifts/flickers vertical  (Read 1909 times)
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« on: May 18, 2003, 08:35:58 am »
Just moved my cab one room further - the last time I played I notices my monitor (Wells Gardner U3100 -arcade vga monitor) has a little vertical flickering!  :o
Somehow the picture moves/flickers up and down, barely noticable, but still driving me nervous! It flickers only less then a pixel height up and down, but it's definitely there!
Anyone an idea where I could start to look at?  ??? I've all circuits diagrams here -would be easier to find the fault when the picture would be dead instead of this!
I tried other plug-sockets in the house as well, also I turned of the marquee-lights, no changes there. In windows it's still a standard vga-monitor, switching from standard to optimum in the graphics-driver doesn't change anything. I made no changes in my configuration anyway.
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:WG U3100 - picture shifts/flickers vertical
« Reply #1 on: May 18, 2003, 06:34:27 pm »
Jiggle your V.Hold knob a bit.
« Last Edit: May 19, 2003, 06:08:51 pm by tom61 »
Carsten Carlos
« Reply #2 on: May 19, 2003, 10:51:05 am »
Good idea - would love to, but it seems that is has none!  ??? At least it's not in their servicemanual/pdf-file I got here.
tom61
« Reply #3 on: May 19, 2003, 06:07:46 pm »
Odd. There should be a Vertical Hold knob.
