Author Topic: Does a touchscreen monitor only report CLICK events only?  (Read 1817 times)
unclet
« on: January 29, 2008, 01:14:00 pm »
In my jukebox software if the user wants to increase the volume then the user can click the increase volume button using the mouse.  If the user clicks one time (ie: presses down the left mouse button and then releases the left mouse button quickly) then the volume is increased by one interval only.  If the user presses the left mouse button down and keeps it down, then the volume is increased continuously until the user releases the left mouse button.
Now, if I install a touchscreen monitor (ie: no more mouse interface), then can the user have the volume continuously increase by pressing their finger on the volume button, or will the touchscreen simply report this as one click only, thus resulting in a one interval volume increase only?
Hope this question made sense....
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Does a touchscreen monitor only report CLICK events only?
« Reply #1 on: January 29, 2008, 01:47:20 pm »
Depends entirely on the software you write for it. But usually they behave like a key press. So the longer you are touching it the longer it shows as held down.
You can touch and drag on most touch screens. So you could even have a slider for volume control.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
« Reply #2 on: January 29, 2008, 02:02:09 pm »
Yea I have an option in the software I have called "Constant Touch"
unclet
« Reply #3 on: January 29, 2008, 06:14:01 pm »
Ok, thanks for the information
DiGi
  • Last login:February 12, 2008, 06:50:28 pm
« Reply #4 on: January 31, 2008, 06:01:11 pm »
Works fine on a elo software when option is set to mouse emulation,  if set to cick on touch it has to be repeatedly pressed to go up or down.
DiGi
unclet
« Reply #5 on: January 31, 2008, 06:58:50 pm »
excellent ... at least I know it is possible .... I have an ELO touchsreen
