Author Topic: Controllers in Zsnes doesn't work when loading with MAMEWAH  (Read 1654 times)
roelieboelie
  • Last login:September 05, 2008, 09:11:04 am
« on: January 23, 2008, 02:36:15 am »
Hi all,
I'm building an arcade cabinet for my own. I use en simple front end called MAMEWAH to select all my games and select the platform (Zsnes, n64, mame, etc).
Everything works fine, except the controls in Zsnes if I load a snes game in mamewah.
I can push on my joysticks what I want, but I get no reaction.
Is there something that i get my joysticks work in Zsnes when i'm loading a game in mamewah? Must I change something in de *.ini files from mamewah / Zsnes?
Thank you!
Roel
from the netherlands
P.S: If I start ZSNES stand alone, the joysticks works fine. Strange, isn't?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Controllers in Zsnes doesn't work when loading with MAMEWAH
« Reply #1 on: January 23, 2008, 11:52:53 am »
It all depends on how your joysticks are connected to your PC - via a hacked joypad or some other way?
I've worked with Mamewah for ages and not envcountered strangeness like this.
unclet
« Reply #2 on: January 23, 2008, 02:42:17 pm »
I have no idea since I am at work right now, but does ZSNes default to "keyboard" mode and perhaps require the user to turn on "joystick" mode?
Can you play a ZSNes game by starting it manually (ie: not by using MameWah at all) and have your joysticks work properly?
Are you using normal 8-way joysticks, U360 joysticks, joystick hack connected via serial port, etc.. etc...?
« Last Edit: January 23, 2008, 02:44:34 pm by unclet »
roelieboelie
« Reply #3 on: January 24, 2008, 10:13:57 am »
Alright, the following:
I have ONE frontend called MAMEWAH for my arcade games (MAME emu.) and Super Nintendo Games (Zsnes emu.)
I also have controlls for my arcade games (arcade joystick and 6 buttons) and I have 2 joypads for my super nintendo games.
So if I start Zsnes alone (without mamewah) the joypads works great.  :cheers:
If I start Zsnes with MAMEWAH, my 2 joypads don't work anymore.  :badmood:
I searched on the internet and i think it has to do with "window focus", Zsnes isn't focus when loaded with mamewah.  :cry:
I also found that I have to play with {dosbox} and {safelaunch} to solve the problem, but that doesn't help.
Can you help me?  :D
Turnarcades
    • Turnarcades
« Reply #4 on: January 24, 2008, 12:40:48 pm »
I use MAMEWAH 1.61, but here is my .ini file...
### SNES.ini (mamewah v1.61) ###
emulator_title                            SNES
### List Generation Settings ###
rom_path                                  c:\SNES\roms
rom_extension                             ZIP
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\SNES\zsnesw.exe
commandline_format                        "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
alt_commandline_format_1                  "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
alt_commandline_format_2                  "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\SNES\snap
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path                        c:\SNES\movies
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
