Author Topic: i need some help  (Read 1162 times)
dirt
  • Last login:October 30, 2024, 08:36:38 pm
i need some help
« on: January 23, 2008, 02:33:27 am »
i have a tempest upright cab that has been gutted and jammatized(not by me). i also have a 21" vga monitor and a couple computers laying araound.  becuase tempest has no joysticks to help navigate i want the cab to start up and go directly into tempest tubes. what would be the best front end for that and how could i do it. please explain it  to me like a person who doesn't work with computers, im a construction worker. ;D
thanks guys
WANTED: NINTENDO CABINETS WORKING OR NOT
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: i need some help
« Reply #1 on: January 23, 2008, 04:08:08 am »
Hi,
I have a Atomic user who uses Atomic in a Tempest Cab.
But  If you want only tempest in your cab.  You don't need a front end.
Just make mame start Tempest game at boot .
That easy.
Do you know what OS you will use?  Windows, Dos, Linux??
dirt
« Reply #2 on: January 23, 2008, 11:48:38 am »
i have a computer with windows, older ver of mame(not sure of ver) and mamewah. i had this in a machine about 3 or 4 years ago.
Havok
  • Trade Count: (+17)
« Reply #3 on: January 23, 2008, 10:38:28 pm »
If you just want a down and dirty option to start mame, create a text file that contains something like this:
C:\Mame\mame.exe tempest
(Assuming you put Mame on the root of your C drive)
Save it as Mame.bat, and put it in your startup folder of Windows. When the computer starts up, it will run that command and start up Tempest. If you are using Dos, then you would put that command in the Autoexec.bat file. If you need some help with it, let us know what operating system you are running, and where mame is located...
Or you could use AtomicFE - there is an option to start a game by default. However, quite honestly, it really would be overkill to just run one game.
dirt
« Reply #4 on: January 24, 2008, 01:44:31 am »
thanks i'll get that computer out tomorrow and try it out.
dirt
« Reply #5 on: January 24, 2008, 07:13:49 pm »
just to be clear. when you say text file do you mean use notepad or something else? sorry i am not a software guy at all. put a tool in my hand and im at home, but software is just not my thing.
crummy
  • Last login:May 11, 2008, 03:01:58 am
« Reply #6 on: January 24, 2008, 07:42:11 pm »
Notepad would likely be best.
Havok
« Reply #7 on: January 24, 2008, 08:31:26 pm »
Yep - just like crummy says, Notepad is fine. Just make sure to do a save as, and give the filename a .bat extension.
