Author Topic: Pentranic/Rodo Tron CH-281 problem  (Read 2864 times)
nstg8r
  • Last login:December 15, 2011, 06:03:59 pm
« on: January 21, 2008, 01:59:38 pm »
Hi, I'm fairly new to the scene, and am having some problems with an arcade cab monitor. I have a Pentranic CH-281 PCB and 25" monitor driven from ArcadeVGA and video Amp. The problem is that I cannot dial in the screen properly - windows is slanted and shifted, games are rendered the same way.
This is the slant:
This is the PCB:
Is this a problem that is easily fixed by a cap kit? BTW, if anyone knows where to get a kit for this please let me know - I cannot find anyone with it.
Also, I've tried contacting Pentranic for schematics but they suggest I look at the CH-288.
grantspain
Re: Pentranic/Rodo Tron CH-281 problem
« Reply #1 on: January 21, 2008, 02:02:27 pm »
you have the sync connected incorrectly
nstg8r
« Reply #2 on: January 21, 2008, 02:09:33 pm »
It's a composite sync, is there any way to change it?
btw, thanks for the quick reply!
grantspain
« Reply #3 on: January 21, 2008, 02:29:39 pm »
don't know jack about mame but the picture you posted shows no sync,now either you have two connections on the monitor plug(1 vertical sync and 1 horizontal sync) or you may have one sync connection and a sync switch(hopefully)
i am guessing this happening on the boot screen as well?
nstg8r
« Reply #4 on: January 21, 2008, 02:58:16 pm »
 :applaud: :applaud: :applaud:
Haha, success - grantspain thanks, you were correct. I didn't have the sync connected - I made an assumption that the white wire I connected was the same white wire at the board. Turned out there was a splice made in the loom.
Thanks again
