Author Topic: Does Anyone know if this Coin Door has LEDs?  (Read 1787 times)
HedonismBot
  • Newbie
  • Last login:April 12, 2008, 07:35:13 pm
« on: January 19, 2008, 09:19:10 pm »
http://www.happcontrols.com/coindoors/40071300.htm
If not does anyone know if LEDs can be added after the fact? I don't need a high quality coin door as it's just for show. However having a glowing coin slot is very important even if you can't insert coins.
I'm planning out my first cabinet. I've read the heck out of this site and this is the first time I've had need to ask something.
Thanks.
Level42
Re: Does Anyone know if this Coin Door has LEDs?
« Reply #1 on: January 20, 2008, 06:09:37 am »
No coin door has LEDs. Coin doors have light bulbs. You never get the same look with LEDs.
You can put bulbs in the mechanisms that you need for the door. But you could easily wire something behind the push buttons also. However, the pushbuttons will need to be fixed in some way if you're not going to install coin mech(s).
B.t.w, I would get red buttons instead of the showed yellow, but that's a matter of personal taste/historical preference :D
