Author Topic: ArcadeVGA2 + Billabs 1024x768  (Read 1073 times)
metahacker
  • Last login:January 17, 2024, 03:09:39 am
« on: January 16, 2008, 01:14:34 am »
Is anyone using this configuration?
Any results to report?
How is MAME with switch res enabled?
How does 1024x768 look?
Are there any issues ?
Do you have to tweak the monitor adjustment settings ?  Any issues specific to that ?
Anyone using this monitor with Sof15KHz and a newer ATI ?
northerngames
  • Trade Count: (+18)
Re: ArcadeVGA2 + Billabs 1024x768
« Reply #1 on: January 16, 2008, 09:19:41 am »
arcadevga does 15k
you want your desktop set at 640x480
also run the avres tool to automaticly adjust the res to make the game of choice run native.
read the istruction at ww.ultimarc.com in order to get the correct display's out of your card.
if you dont follow the directions you will not get any benefits out of the card.
