Author Topic: What monitor was used in a NBA Showtime arcade game?  (Read 1309 times)
JimmyU
  • Last login:April 13, 2025, 05:13:57 pm
  • I believe I can fly!
« on: January 15, 2008, 01:06:39 pm »
I know the game used some weird 57 Hz frequency so was the monitor different than a normal medium resolution monitor?  Thanks for your input.
Kevin Mullins
    • Me on Myspace
Re: What monitor was used in a NBA Showtime arcade game?
« Reply #1 on: January 15, 2008, 01:17:58 pm »
Equipment Characteristics
Video Display Monitor
• 25” (63.5 cm) CRT
• Medium Resolution RGB
• DIP Switch U12-2 sets resolution
• SIO Jumper J2 sets sync polarity
Looking at the dipswitch settings it shows it to be switchable between medium res and low res. So it should also be able to run on a standard resolution monitor as well as the medium res. Probably came with a medium res in the dedicated cab, but can also still be installed in a conversion cab with a standard res monitor.
