Author Topic: Joystick suggestions...  (Read 2876 times)
CCM
« on: May 15, 2003, 02:16:50 pm »
I am going to add a dedicated 4-way joystick to my cp, any suggestions on which one to go with?   ???
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
Re:Joystick suggestions...
« Reply #1 on: May 15, 2003, 02:18:21 pm »
I like the j-stick by Ultimarc........why? Its got a dedicated 4 way to 8 way converter plate underneath it, and its got the bright red gumball top.  Che' Classic. :)
".....its like a Koala crapped a rainbow in my brain!"
hyiu
    • www
« Reply #2 on: May 15, 2003, 02:21:29 pm »
if you have a 3/4 wood panel, then I think J-stick will do fine for you....
I only have VERY limited knowledge on 4 way sticks... but if I remember correctly... those 4 way sticks are even shorter...
maybe you can look at Happs and see... they have all the dimensions and so on...
CCM
« Reply #3 on: May 15, 2003, 02:31:59 pm »
whoops... I should have noted that my cp is 3/4" MDF.  I like the look of the J-stick as well, but how does it feel?  Sturdy, loose, etc...
CCM
« Reply #4 on: May 15, 2003, 03:24:09 pm »
Also, does anyone know the dimensions of the J-stick?  My cp is getting a little crowded, and I want to make sure it will fit.  I checked ultimarc's website and did't see the dimensions anywhere...
hyiu
    • www
« Reply #5 on: May 15, 2003, 03:27:44 pm »
if I didn't remember wrong, the j-stick has the same mounting as the competition and Super....
But the unit itself takes a little less space...
J -stick is a little more compact than the competition and Super...
CCM
« Reply #6 on: May 15, 2003, 03:34:15 pm »
Cool!  It should fit on my CP with no problems!  Thanks for the help!
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #7 on: May 15, 2003, 04:12:26 pm »
Hyiu are you sure about that?  I want them to be standard/the same as I'd love to switch out my super clones with a t stick but i thought  i read somewhere that they weren't...  I may be wrong... but could some one check/verify?
rampy
CCM
« Reply #8 on: May 15, 2003, 04:25:29 pm »
Never Trust Anyone Who's Username is in ALL CAPS
Hey!  what's wrong with a username being all caps!?  hehe
rampy
  • *shrug*
« Reply #9 on: May 15, 2003, 04:30:00 pm »
all I can say is if the shoe fits... =P  but if the shoe doesn't fit, disregard...  Lets just say i've noticed a correlation between caps locks and unintelligible postings.
Your username is clearly an acronym or initials so it makes sense for it to be in all caps.
*shrug*  good luck with the j-sticks...
rampy
CCM
« Reply #10 on: May 15, 2003, 04:38:31 pm »
ha!  it's actually my initials.  But I am unintelligible somtimes, like Friday afternoons, after a long week of work.  So watch out if I post tomorrow!
 I'm going to go ahead and order a j-stick.  This will also keep the wife happy!  She doesn't like the current location of the joysticks and the fact that they are 8-way.  The j-stick should fit nicely in the middle of my cp and allow her hours of Ms Pac-Man and Frogger fun!
hyiu
    • www
« Reply #11 on: May 15, 2003, 04:40:24 pm »
Up to my limited memory....
I have ONLY done1 template size for joystick....
and I have mounted Super, Competition, and J-stick...
I DO have an extra J-stick and Comp at home....
If I can dig it out from the BIG BOX full of pieces....
I'll measure.....
If I didn't remember wrong... the J-stick has the same mount... but the T_stick has a different mount....
Now... I CANNOT guarantee this for now... especially I DO NOT have a T-stick....
let me go home and take a look and I'll post another post tonight on this thread and let you know....
(I'll confirm the mounting for J-stick and Competition tonight..)
ok ???
HeadRusch
« Reply #12 on: May 15, 2003, 06:51:00 pm »
I just mounted a J-Stick on my CP along with Supers.......same template was used, same holes drilled.
What I want to know is: Why are ALL JOYSTICK HOUSINGS closer to the bolt holes on one side? :)
On the JSTick and the Supers, I can get my 10mm socket on THREE corners but NEVER the fourth...there isn't enough space between the plastic of hte joystick housing and the edge of the nut for the socket to slip in between!
Whatta pain :)
hyiu
    • www
« Reply #13 on: May 15, 2003, 11:49:16 pm »
sorry I'm late... (already confirmed by headrusch...)
but the J-stick does have the same mounting screw holes as the Super or Comp....
I believe its the T-stick that has a different mount...
austinrfnd
  • Last login:March 28, 2004, 06:13:42 pm
« Reply #14 on: May 16, 2003, 04:16:30 am »
All i know is that you should stay away ffrom Happ''s Ultimate 4-way joysticks.  In one word they suck.  this conversation has been brought up a lot lately on this forumn.  I have heard nothing but rave reviews from the J-sticks.  IIf I were to buy another 4-way joystick for my control panel, I would probably buy Happ's galaga/ ms. pacman joystick or whatever.  Imy reasoning is that why not use a 4-way joystick that was made ffrom the games that pracitcally invented the 4-wayer
-Austin
paigeoliver
  • Awesome face!
« Reply #15 on: May 16, 2003, 04:32:40 am »
I have two of the Ms. Pac-Galaga sticks and they are the best 4-ways I have ever owned.
