Author Topic: Jamma 2 PC monitor  (Read 1960 times)
Yooyenkoo
  • Last login:May 11, 2009, 02:29:51 pm
    • NDS-Anime
Jamma 2 PC monitor
« on: January 07, 2008, 10:49:19 pm »
Is there any way of doing this? I know you can do an arcade monitor to pc but i want to know if it's possible to do it the other way around and do a jamma to pc monitor?
Yooyenkoo
    • NDS-Anime
Re: Jamma 2 PC monitor
« Reply #1 on: January 10, 2008, 02:36:10 am »
No one able to think of anything to solve this?
StephenH
« Reply #2 on: January 10, 2008, 03:05:48 am »
Yes, you need a CGA to VGA scan converter, such as this:
http://www.converters.tv/products/cga_to_vga/41.html
northerngames
  • Trade Count: (+18)
« Reply #3 on: January 10, 2008, 09:57:17 am »
I thought the ultimarc j-pac was made for that purpose?
it allows a jamma set-up to display on a pc monitor.
shardian
« Reply #4 on: January 10, 2008, 10:31:38 am »
A Jpac allows you to interface your existing control wiring to the pc. It also allows has a video amp, and a chip that blocks any signal other than 15khz and/or cuts it in half to diplay.
It still takes a bunch of work to get your pc to output a valid arcade monitor signal.
