Author Topic: Quick disconnects for atari volcano/cone buttons?  (Read 1968 times)
Justin Z
  • Last login:December 18, 2025, 09:47:41 am
« on: January 05, 2008, 08:04:57 pm »
These are really tiny connectors.  Anyone out there who has this style button have a suggestion for finding the proper sized quick disconnects (if they exist) or any other alternative to soldering?
Thanks,
Justin
Re: Quick disconnects for atari volcano/cone buttons?
« Reply #1 on: January 05, 2008, 08:15:12 pm »
Solder them.  If you're building custom stuff, or restoring a game of that age, you should know how to solder leaf contacts.  It's not hard.
Justin Z
« Reply #2 on: January 05, 2008, 08:22:09 pm »
No, it's not.
That said, since nothing else in the entire CP is permanent, I'd rather have the ability to change these if I feel like it as well.
If that's not possible, that's fine, but I'd prefer the option one way or the other.
Lindner24
  • Last login:May 20, 2008, 10:06:12 pm
« Reply #3 on: January 05, 2008, 11:58:58 pm »
I've never hooked up volcano buttons...
Although, I've had good luck using regular sized quick connects on small pins.
You might have to adjust them with a pliers a little for a good friction fit.
In other words, just use half of a quick connect pinched with a pliers.
Justin Z
« Reply #4 on: January 06, 2008, 05:35:49 am »
That sounds like it's worth giving a shot, thanks.
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #5 on: January 06, 2008, 08:53:55 am »
That's what I did with mine.
Since then I have seen 3/16" QDs at Radio Shack, so smaller ones do exist if you want to go to the trouble.
Level42
« Reply #6 on: January 06, 2008, 04:26:29 pm »
I don't know their size, but I used the smallest disconnects that I found in my stockpile of arcade related parts for my Centipede volcano's....
They fit quite well and don't come loose.
MaximRecoil
« Reply #7 on: January 06, 2008, 05:07:33 pm »
3/16" = .187", i.e. the size for normal button and joystick microswitch tabs, which I would assume is too wide.
They do make very narrow QD's (I would guess 1/8"). Check your local car audio shop. A lot of car audio speakers have a normal 1/4" QD tab and a very narrow QD tab (looks to be about half the width). This is to prevent the installer from accidentally reversing the polarity of the speakers. I've bought some of these very narrow QD's from a local car audio place for my car speakers, and it is the only place I've ever seen that had them. They look just like the typical crimp-on half-insulated QD's, except about half the width.
Edit: It looks like Mike's Arcade has them - http://www.mikesarcade.com/cgi-bin/store.pl?sku=QD110RED
Don't know if that's the right size for volcano button switches or not—you'd have to measure the width of the tabs.
« Last Edit: January 06, 2008, 05:51:19 pm by MaximRecoil »
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #8 on: January 06, 2008, 06:06:45 pm »
A .110 disconnect is what I used on a custom CP fro a freind 2 years ago and they still hold just fine.
There are three kinds of people in the world those that can count and those that can't.
