Author Topic: Paint Sprayers  (Read 3914 times)
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Paint Sprayers
« on: May 14, 2003, 10:00:25 pm »
I just did a search, and found no information regarding paint sprayers, or anyone that has used one.  Well, in truth, I did find one comment out of the whole board, but that was it.
I'm looking for information on paint sprayers.  What's a good brand/model, how easy they are to use, cleanup, etc.
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
Re:Paint Sprayers
« Reply #1 on: May 14, 2003, 10:18:24 pm »
Not a fan :( They can cause a nasty mess in my expieience; (paint everywhere!)
Visit my MAME lightgun site:
http://www.lightgun.tk
SirPeale
Re:Paint Sprayers
« Reply #2 on: May 14, 2003, 10:54:21 pm »
I've done a little bit of research, and think that an 'airless sprayer' might be the thing to get.  Well, rent anyway.  They're really expensive for one or two uses.
anthony691
    • Lightgun.tk
Re:Paint Sprayers
« Reply #3 on: May 14, 2003, 11:22:03 pm »
Maybe because I am bad at painting... but I really didn't like it... I still have specs on my shoes.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Paint Sprayers
« Reply #4 on: May 14, 2003, 11:26:45 pm »
Why don't you all use tux as an avatar  ;D
anthony691
    • Lightgun.tk
Re:Paint Sprayers
« Reply #5 on: May 14, 2003, 11:29:18 pm »
Yeah, we disscussed this before... I'll change it soon... He was here first, but didn't post much so I didn't notice.
SlikStik-Christian
  • Last login:November 04, 2004, 10:28:08 pm
  • Gaming will never be the same...
    • SlikStik Arcade Controllers
Re:Paint Sprayers
« Reply #6 on: May 15, 2003, 01:21:56 am »
I use airless sprayers alot. IMO using one to spray an arcade cab is more work on the clean up of the machine than its worth, your gonna spend about 4 minutes painting and about 20 minutes cleaning the machine. I think a roller will do a great job. I used a roller to stain and poly my cab. You can see it at http://www.instantlink.com/mame/
Thank You
Christian
SlikStik Customer Support
http://www.slikstik.com
The Worlds Best Arcade Controllers
SirPeale
Re:Paint Sprayers
« Reply #7 on: May 15, 2003, 08:10:00 am »
Do you have some close ups of the paint itself?
I asked in RGVAC, and a lot of people recommend spraying the paint, as opposed to rolling it on.  You can get an acceptable finish with a roller, but I'm looking  for something smooooooooooth.
For that matter, what does everyone recommend as a paint?  Gloss? Matte?  Flat?  Oil?  Water based?  Latex?
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
Re:Paint Sprayers
« Reply #8 on: May 15, 2003, 08:32:56 am »
I got a very smooth clean finish from a roller.  Here is what I recommend.  Use primer first.  Get a HIGH quality semigloss (or gloss) latex paint and apply at least 2 coats.  Also, use a good smooth roller and let the paint fully dry before adding a second coat.  I have looked at hundreds of mame cabinets and I can always tell the people that use spray paint.  In my opinion, it always looks spotty.  Using latex paint is easy, quick and cheap.
Good luck
said7
  • Last login:January 24, 2012, 02:24:47 pm
  • "I smell..... NERDS" - Ogar
    • www.said7.com
Re:Paint Sprayers
« Reply #9 on: May 15, 2003, 10:05:20 am »
I use a compressor and a spray gun and that is the best imo.
If you cant afford all that use spray paint or a roller.
Its more of a luxury than a necessity.
Check out my site: http://www.said7.com
Arcade site comming soon.
SirPeale
Re:Paint Sprayers
« Reply #10 on: May 15, 2003, 11:36:46 am »
Probably because the people who sprayed their cabinets didn't prime, and used cheap paint.
I'm looking to spray a decent latex paint (I think it'll be the easier cleanup, plus if anything happens to the cabinet I can touch up easily)
SirPeale
Re:Paint Sprayers
« Reply #11 on: May 15, 2003, 11:37:50 am »
Most certainly, but I plan on keeping this cabinet a long, long time.  I want to make it look good.  That, and if it looks like crap, the wife won't allow me to have it in the house, and it'll have to stay on the porch.   >:(
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
Re:Paint Sprayers
« Reply #12 on: May 15, 2003, 01:30:25 pm »
For my current project, I just finished painting the top - I used a roller - 3 light coats with a 'super-fine' roller I got from HD.  It's not as wide as my other one but gives an excellent seamless finish with only a hint of texture.
Maybe if you were busting out 4 or 5 cabs at a time then I'd say go with the spray gun  - not really worth it for only 1 cab, IMHO.
SirPeale
Re:Paint Sprayers
« Reply #13 on: May 15, 2003, 03:06:37 pm »
Well, I've got two current projects.  And I'll rent, not buy one.  That (in theory) shouldn't be too much.
Ledbetter
  • Last login:March 01, 2005, 08:13:19 pm
Re:Paint Sprayers
« Reply #14 on: May 16, 2003, 06:19:38 pm »
  I also use a compressor/spraygun for painting. If your going to use latex the cleanup is a 5 minute job. A good way to control overspray is to create a homemade spraybooth with plastic sheets. I just hang them from the garage ceiling and wheel the cab in and start spraying.
  I've gotten good results from the low cost sprayguns from DeVilbiss and Campbell Hausfeld.
SirPeale
Re:Paint Sprayers
« Reply #15 on: May 16, 2003, 07:58:19 pm »
How much are these sprayers?  What model did you use?
I'm pretty sure I'm going with an airless, but I like to keep my options open.
  • Last login:June 18, 2026, 02:39:45 pm
    • GroovyGameGear.com
Re:Paint Sprayers
« Reply #16 on: May 16, 2003, 10:58:38 pm »
I painted a car with an airless sprayer once (ok, I was young and stupid, your point?  :D)
They're ok for painting fences, patio furniture, maybe even a small house, but unless there have been some major advances in airless technology in the last 19 years (and there probably has) don't expect an incredible finish.  They typically can only cover small areas at a time, are noisy and are pretty tempermental with paint viscosity (if the paint is too thick, it can actually damage them).
Likewise, if you aren't comfortable with a regular air sprayer, you could get poor results with that as well.  Don't even think about spraycans, unless you are after the grafitti look.
On the other hand, a high quality roller and some good paint will probably come out better than you think.  Just don't skimp on the roller if you go that route!  Nothing screws up a paint job worse than roller fuzz all over your project (except maybe cat footprints :) )
Ok, enough preaching.  Here's a place I just found (never did business with them)
http://www.gleempaint.com/powersprayer.html
They start at (reconditioned) $45.00
anthony691
    • Lightgun.tk
Re:Paint Sprayers
« Reply #17 on: May 17, 2003, 12:55:05 am »
20-30 cans of spray paint should be enough
JK :P
Apollo
    • Eight Bells
Re:Paint Sprayers
« Reply #18 on: May 18, 2003, 12:13:22 am »
I recommend using auto paint in a spray can. If you spray properly you will have no problems with poor coverage. Prime first. Auto paint is awesome as you can get a huge variety of colours and effects these days ( glitter, metallic etc ).
