Author Topic: Deciding on a Light Gun  (Read 2999 times)
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
« on: January 02, 2008, 09:18:46 pm »
Which light gun should I buy? I'm trying to decide between the Act-Labs or the LCD/EMS Topgun.
Thanks,
Xb0x3r
TPB
  • Last login:March 01, 2021, 09:12:52 pm
Re: Deciding on a Light Gun
« Reply #1 on: January 02, 2008, 09:47:53 pm »
This question must have been asked in 100 other past threads.
But maybe new info. has come to light, based on recent user experiences.
** The type of monitor or TV you're using, is one factor in deciding which light gun to buy.  Are you using a CRT display, or other display type (LCD, plasma, etc.) ??
>> If you're NOT using a CRT (eg, LCD, plasma, etc.), then the LCD Top Gun is the only option.
** Another factor is "how far back" you wish to stand from the display ??
>> This is not a factor with the ACT Labs guns.  However, with the LCD Top Guns, you need to stand back a minimum of 3 feet "for every" 1 foot gap between the LCD bars that must be placed on either side of the display.  So, the wider the display, the further you'll need to stand back.
btp2k2
  • Last login:March 16, 2011, 01:02:36 pm
« Reply #2 on: January 02, 2008, 09:52:09 pm »
Also...with the TopGun you need to use LCD sensor bars...so if you are using the guns in a cabinet, you will have ugly sensor bars on the sides of your screen
M37R01D
  • Last login:April 25, 2009, 06:23:25 pm
    • M37R01Dz M0Dz
« Reply #3 on: January 03, 2008, 12:10:07 am »
I have the act light guns
They do work pretty nice, the only thing that does suck, since they aren't IR based, then you move the gun, the crosshairs dont move, only when you hit the trigger, will the crosshair/cursor move.
btp2k2
« Reply #4 on: January 03, 2008, 02:21:12 am »
That is pretty much how light guns worked in the arcades.
  • Last login:July 11, 2025, 09:17:44 am
« Reply #5 on: January 03, 2008, 05:40:03 pm »
Can't you turn off the crosshairs by pressing F1?
M37R01D
    • M37R01Dz M0Dz
« Reply #6 on: January 03, 2008, 05:45:26 pm »
Yes I compiled my MAME to not show crosshairs default. and F1 turns them on
I guess I got used to the Wii and its IR sensor  :o
AcidArmitage
  • Last login:February 21, 2015, 02:19:05 am
  • keeeyaaaii
« Reply #7 on: January 04, 2008, 12:22:03 pm »
guncons are prettier
