Author Topic: Golden Tee Monitor too FAT!!!  (Read 2278 times)
fairway2000
  • Last login:April 21, 2012, 06:53:54 pm
  • Loooking for games in Detroit
« on: December 28, 2007, 07:53:56 pm »
I have a golden tee that you can not see both sides of the screen(too fat). I tried adjusting with the remote adjustment control but it will not adjust. My question is. Do the adjustment pods on these controls go bad very often?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Golden Tee Monitor too FAT!!!
« Reply #1 on: December 28, 2007, 08:13:35 pm »
a few diff failures may cause this symptom. ( pwr sup, hsweep , pincushion - if crt 27+ " )
what is the make/model of the monitor ?
qrz
fairway2000
« Reply #2 on: December 29, 2007, 12:49:18 pm »
It looks like it is a Neotec 2701. I changed the pot on the remote and nothing happened. It was the H-Hold pot.
Any ideas on what to try next?
Pete
northerngames
  • Trade Count: (+18)
« Reply #3 on: December 29, 2007, 02:10:17 pm »
my monitor is a different make and model but it has a wire loom that can be swapped from each pin set on the chassis 1 for standard display and one for a widescreen display you may want to check to see if yours has a set-up like that and if so it may be set on wide when you want it set at standard.
qrz
« Reply #4 on: December 29, 2007, 08:49:27 pm »
hsize is VR2 (100k pot) if no change...
check Q3 (2sc2073), R31(5.6ohm/2w), C24(.7uF@400v)
emitter voltage of Q1(2sc458) should be around 19.3v  / collector Q3=27v , base=20v
'lytic caps C6-8 (10uF/50v),C16(22uF/50v),C9(4.7uF/50v)and C19(5.6uF/50 non-polarized i.e. bipolar)will have an effect with value change/high esr, etc....
not the best rendering , but have a print if u wish ....pm request  ;)
qrz
fairway2000
« Reply #5 on: December 31, 2007, 02:47:38 pm »
I shorted out the Hsize pot and the screen had know change. I will check the other info you gave me.
pete
