Author Topic: please help! - jerky mame with arcadevga - SOLVED!  (Read 2433 times)
Jimbo
    • Wood Finishes Direct
« on: December 24, 2007, 04:53:50 pm »
I've tried quite a few games now (mame 0.116) and I'm getting a small jump/jerk/flicker every 1 or 2 seconds.
I've uploaded a short video of it . After the first wave of 2 or 3 baddies if you look at the bottom half of the screen (in the rocks) you can see what I mean (every 1 or 2 seconds).
My specs are: -
Asus P5B Motherboard
Intel Core2Duo 2.4ghz
2GB DDR2 RAM
ArcadeVGA2 PCI-E
SB-Audigy Sound Card.
WinXP SP2
Even with the jerking I've not noticed any stuttering of sound.
I'm using the following settings in mame 0.116: -
hwstretch 0
video ddraw
waitvsync 0
syncrefresh 1
triplebuffer 1
switchres 1
tried setting priority to 1 and sleep to 0, and also tried waitvsync 1 but it has no effect on the jittering...
Any ideas? Its a fresh clean system (just installed). I've tried stopping various non-essential services and systray apps but nothing seems to have any effect! Please help!
« Last Edit: December 26, 2007, 10:25:21 am by Jimbo »
northerngames
  • Trade Count: (+18)
Re: please help! - jerky mame with arcadevga
« Reply #1 on: December 24, 2007, 04:57:02 pm »
screen resolution size?
Jimbo
« Reply #2 on: December 24, 2007, 05:08:23 pm »
Hi northerngames...
What exactly do you mean?  I'm running the games at their native resolutions (320 x 240 @ 60 Hz in the case of Rastan).  I'm using the AVGA card connected to an LCD currently, but will move to the arcade monitor in the cab once I've set up everything.  Am I missing something?
northerngames
« Reply #3 on: December 25, 2007, 03:25:32 pm »
can a lcd even support a res size that small?
that is why a arcae moniotr is good becuase it can display low res images that vga and such cannot.
Jimbo
« Reply #4 on: December 26, 2007, 10:25:01 am »
fixed it.
turns out the juddering was caused by me using a DVI to VGA adaptor when testing the AVGA card on my PC...  when I plug the VGA cable direct from card to arcade monitor its fine. :)
northerngames
Re: please help! - jerky mame with arcadevga - SOLVED!
« Reply #5 on: December 27, 2007, 12:27:46 am »
yes the vga slot is 15k only and the dvi is actually the vga on these type cards  :cheers:
