Author Topic: Exact replacement for a pacman joystick?  (Read 4176 times)
2PacMan
  • Last login:November 06, 2009, 08:33:45 am
  • PacMan collection
« on: December 19, 2007, 11:20:42 am »
Is there any places that sell an exact replacement for the pacman joystick?  The reunion joysticks are microswitches and the ball top doesn't look the same.  I got a cheap leaf switch joystick and replaced the shaft/balltop with a pacman shaft/balltop, but it doesn't fit quite right, it's still loose.
Bottom line, is there any place that sells the exact stick?  The base, stick, switches, everything in one?
shardian
Re: Exact replacement for a pacman joystick?
« Reply #1 on: December 19, 2007, 11:43:51 am »
I can't remember exactly where, but I believe I have seen NOS before...they were mucho expensive though. I'll try to locate it again.
2PacMan
  • PacMan collection
« Reply #2 on: December 19, 2007, 11:45:32 am »
yeah, let me know if you can....the only NOS ones i can find are the reunion sticks, which are quite different.
shardian
« Reply #3 on: December 19, 2007, 11:48:11 am »
If you can get ahold of some WICO 4-ways, you can use the adaptor plate the Bob roberts sells to make them fit the pacman. That will be about the best leaf replacement you could use.
hsstie
  • Last login:August 05, 2008, 02:24:40 pm
  • Did someone say FREE games?
« Reply #4 on: December 19, 2007, 11:13:04 pm »
« Last Edit: December 19, 2007, 11:26:16 pm by hsstie »
BrentRadio
  • Last login:March 11, 2021, 06:26:04 am
  • Stop by for a game and a beer!
    • Jack Daniel's Barcade!
« Reply #5 on: December 20, 2007, 02:51:55 am »
You could always get an original one.
http://www.quarterarcade.com/Game.aspx/485
Brent
2PacMan
  • PacMan collection
« Reply #6 on: December 20, 2007, 08:22:44 am »
All of the links provided are for sticks with microswitches, and the balltop is not the same.  They will work, but are not identical.  The quarterarcade one is an exact, but used.  I might have to go that route if I can't find anything else.
SirPeale
  • Green Mountain Man
« Reply #7 on: December 20, 2007, 11:40:57 am »
The rubber grommets are available brand new.  Unless there's other things wrong with the joystick, this should bring it back to working condition.
2PacMan
  • PacMan collection
« Reply #8 on: December 20, 2007, 03:22:35 pm »
Where can the new grommets be purchased?  That's the main thing wrong with the stick i currently have.
shardian
« Reply #9 on: December 20, 2007, 03:42:27 pm »
They are on ebay fairly frequently. They are pretty pricey though. Expect to pay about $20 shipped.
NoOne=NBA=
« Reply #10 on: December 20, 2007, 06:15:07 pm »
The other two parts that wear out are the shaft cover, and the restrictor at the bottom.
There is a seller that puts the lower restrictors on ebay now and then, and the shaft covers are just a piece of hollow nylon.
You should be able to pick up a suitable substitute at Home Depot.
hsstie
« Reply #11 on: December 21, 2007, 12:14:20 pm »
Ok my bad, didnt know you wanted leaf switch,
heres one new for 20 bucks
http://www.mikesarcade.com/cgi-bin/store.pl?sku=JOYRBLS4W8W
BrentRadio
« Reply #12 on: December 21, 2007, 03:53:25 pm »
That looks like the cheap crap ones.
shardian
« Reply #13 on: December 21, 2007, 08:20:08 pm »
And you would still need the adaptor plate.
