Author Topic: Mamewah Gamelists? I miss the old version.  (Read 1541 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: December 16, 2007, 06:39:50 pm »
I tried searching and it seems that nobody has any current links.
I am using the 1.61 version of Mamewah and I just restored my system with .118 roms. When I first did my system back in 05/06, I was able to create custom game lists very easy. I was able to select which categories I wanted and put all of them together into a list (Tennis, Track, etc in a list called Sports).
How the heck can I accomplish the same now? It seems that all of the good working utilites are gone or out dated.
Any help would greatly be appreciated.
Chris
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: Mamewah Gamelists? I miss the old version.
« Reply #1 on: December 17, 2007, 09:52:52 am »
tried ROMLister?
http://www.waste.org/~winkles/ROMLister
Unless this is considered gone or outdated?  ;)
I'm not very familiar with mamewah, but I believe it can import plain ole text lists, so you should be able to use RL to bulk up a few categories and then copy+paste them together using notepad.
-jeff!
« Reply #2 on: December 19, 2007, 04:36:38 am »
You should be able to generate lists the same...maybe it is the latest -listxml output that is giving you trouble?  If so try the latest beta from the Mamewah board (see my sig).
