Author Topic: Ultrastyle. Need help.  (Read 5256 times)
Namco
  • Last login:August 15, 2026, 11:40:43 pm
    • Freddo Mame Project
« on: December 09, 2007, 04:01:56 pm »
I desperately want to use Ultrastyle. Unfortunately it has been broken for the longest time and the install always hangs on "Shrinker - Reading LI.txt". I've tried it on 4 different computers with the same result everytime. If anyone has some advice or can zip up and send me their setup files for me, let me know.
Cakemeister
  • Last login:June 02, 2026, 11:00:20 pm
Re: Ultrastyle. Need help.
« Reply #1 on: December 09, 2007, 06:39:18 pm »
Try a version of MAME .84 or lower. IIRC Ultrastyle uses the -listinfo option and it was removed from MAME back then.
Old, but not obsolete.
Namco
« Reply #2 on: December 09, 2007, 08:11:26 pm »
I tried on a .64 set I have. how long is it supposed to stay on the shrinking step? Perhaps I'll grab .84 and try again, but how long should i wait? I gave it 45 minutes last time.
Cakemeister
« Reply #3 on: December 09, 2007, 10:30:40 pm »
Don't grab .84. Grab .83.
I did a fresh install with .83 and it was a snap. Make sure you can get MAME running from the command line before you try installing the frontend. That's because Ultrastyle needs to know MAME's rom path.
