Author Topic: paint peeling under machine glass  (Read 2702 times)
BMW Z1
  • Last login:May 11, 2020, 08:23:57 am
« on: December 09, 2007, 11:12:27 am »
Hi,
I have just purchased another Jamma machine for restoring. It has cracks and peeling around the glass that goes over the monitor and is painted on the inside.
I was thinking of removing all the old black paint and repainting it, but I’m not sure what I should be using to repaint it with?. Any help would be gratefully appreciated. Thanks
I was going to try a can of this: B&Q Site
« Last Edit: December 09, 2007, 01:25:22 pm by BMW Z1 »
Spaced Ace
  • Last login:November 03, 2010, 05:48:56 pm
  • "I'm surrounded by arcades!"
Re: paint peeling under machine glass
« Reply #1 on: December 10, 2007, 07:38:08 am »
Are you talking about the bezel part of the wood the glass rests on?  Just paint it if its paint and not vinyl.  I wouldnt spray paint it though.
I suggest a roller or brush, then sand, repaint, sand, paint  and then some clear gloss.
But not spray paint.
You'll regret it later.
« Last Edit: December 10, 2007, 07:41:19 am by Spaced Ace »
BMW Z1
« Reply #2 on: December 10, 2007, 07:52:49 am »
Hi Spaced Ace,
I need to paint the back of the glass itself.
HairyDVD
  • Last login:April 11, 2015, 06:58:50 pm
« Reply #3 on: December 10, 2007, 08:28:12 am »
You would think that if the paint is ok for tiles - then glass should be ok.  May be a bit unpredictable viewing from the inside (may not have the same glossy sheen or appear bumpy or un-even ) - maybe test on some old glass first.
Old Arcade intro videos on Youtube channel : http://www.youtube.com/user/HAIRYDVD
Spaced Ace
« Reply #4 on: December 10, 2007, 04:17:43 pm »
I agree, test it first...
But for some reason spray paint reuns extremely bad on smooth surfaces, even if it is laying flat.
I know it sounds stupid, but once I made a really cool glass bar sign with a thick black magic marker.  I had to 'paint' a tattoo design on a piece of glass and just used 2 really big magic markers instead of paint.
Witchboard
« Reply #5 on: December 17, 2007, 11:14:09 pm »
Use the same method of repairing pinball backglass peeling as described here.
Linolium
  • Last login:October 04, 2011, 03:36:15 pm
« Reply #6 on: December 23, 2007, 01:20:06 pm »
I used my spare black rust-olium spray paint when I needed to repaint the black boarder on one of my glass bezels. It has been about 2.5 years and still looks good.
-Linolium
Working Cabs: Bud-Tapper, JAMMA front loader
Cabs Under Repair: Crystal Castles(Sound Buzz, bad trackball logic)
Projects: Rolling Thunder to SegaSonic conversion
PCBs Under Repair: None
For Sale: Erm, nothing right now...
Wanted: Horrozontal and vertical cabarets, Sonic the Fighters/Championship UR, Tron UR, Frogger UR, Tazz-Mania UR, Pepper II UR
BMW Z1
« Reply #7 on: December 29, 2007, 05:21:44 pm »
Thanks for all comments. I did it with the Plasti-kote tile Spray and it looks like new. It also dried very quickly.
