Author Topic: Think I messed up when I installed one of my U360s (FIXED)  (Read 1328 times)
Gehrig
  • Last login:January 11, 2009, 12:21:06 pm
« on: December 07, 2007, 08:25:09 pm »
I was hurting for room, so I cut U360 mounting bracket.  Took about 1/8" off so I could mount it next to an 8-way.   Problem is, I think the magnet in the U360 is picking up the something in that 8-way.
This is tough to explain.  So let me explain the position of the sticks.
This is a SlikStik Fighter Control Panel.
I mounted a U360 to the Left of the Right 8-way.  The U360 is unable to get anywhere close to the bottom left hand corner in the joystick calibration.  By this I mean it goes from the left postion straight to the down position.  So, my problems seems to occur when the magnet is closest to my 8-way.
Am I way off of thinking this is my problem?  If this is my problem, can anything be done about it?   At this point moving the stick is not an option.
« Last Edit: December 07, 2007, 10:36:33 pm by Gehrig »
crummy
  • Last login:May 11, 2008, 03:01:58 am
Re: Think I messed up when I installed one of my U360s
« Reply #1 on: December 07, 2007, 08:34:29 pm »
The U360 uses a magnet to figure out where the joystick is, right? I'm sure other metal could affect the magnet, and hence the joystick sensor.
I don't know the layout of the cpanel you're referring to, but I'd imagine the joysticks would have to be pretty close.
Gehrig
« Reply #2 on: December 07, 2007, 08:54:46 pm »
Sitting here thinking about it.  My best bet atm, is to just remove the U360 and plug it into my pc to see if there is any difference.
Gehrig
Re: Think I messed up when I installed one of my U360s (FIXED)
« Reply #3 on: December 07, 2007, 10:36:09 pm »
It's working now.  Stupid me.  I hadn't gone through the process of giving each U360 a seperate ID.  After I did that, it worked fine.
Just another of example of an idiot not following directions..... :-[
« Last Edit: December 08, 2007, 12:56:27 am by Gehrig »
