Author Topic: Centipede vs Millipede  (Read 7982 times)
shilmover
  • Last login:September 25, 2018, 12:36:59 am
« on: December 07, 2007, 05:32:41 pm »
Hi all,
I have an option to pick up a Millipeded.  Powersupply needs replacing/fixing...  what is one of these worth? (Dont want to overpay)
Also, what is the real difference between Centipede and Millipede?  can both games exist in a single cab?  Is there a reason to?
Thanks.
« Last Edit: December 07, 2007, 06:40:16 pm by shilmover »
My projects...
Finished:  Stargate (only 'cause I got it that way)
In progress:  Tron, 48-in-1 for School Auction, DKJr (currently a 60-in-1), Millipede, MAME System
Level42
Re: Centipede vs Millipede
« Reply #1 on: December 07, 2007, 05:55:04 pm »
If you have a Millipede you are lucky, there's a multi-game kit to run Centipede on a Milipede board:
http://arcadeshop.com/multipede/multipede.htm
The big difference between Centipede and Milipede is speed and colors I guess....but I never played either on my Jamma cab because I never got to install the trackball......
FrizzleFried
    • Idaho Garagecade
« Reply #2 on: December 08, 2007, 12:08:38 pm »
Millipede is much for frantic...more stuff going on...more enemies to deal with...the play field moves up each stage...lots of things.  Centipede is easier as well.
I like both.
[edit - fixed stage]
« Last Edit: December 08, 2007, 03:41:57 pm by FrizzleFried »
shilmover
« Reply #3 on: December 08, 2007, 02:44:07 pm »
Millipede is much for frantic...more stuff going on...more enemies to deal with...the play field moves up each stange...lots of things.  Centipede is easier as well.
I like both.
Thanks for the info...  Now I just need to talk the wife into it.  :)
My projects...
Kevin Mullins
    • Me on Myspace
« Reply #4 on: December 09, 2007, 03:33:03 pm »
If you look into buying a Millipede.... note what monitor it has in it.
The Matsushita monitors that normally come in those are known to have color guns die in the tube. Which means there will be a color that is very weak or totally dead.
shilmover
« Reply #5 on: December 09, 2007, 03:40:01 pm »
That is good to know!  I will check on the monitor type.
My projects...
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
« Reply #6 on: December 10, 2007, 11:39:14 pm »
This is based on what I read in books, and from what I've seen myself. I'm not sure if I'll make myself clear, either  :-[
With Centipede, you can develop a strategy to win the game. I've seen a guy (back when Centipede was still hot at the arcades) who used to get all of the mushrooms built up with a tunnel, and the centipede would come down the tunnel, and he would shoot it quickly. If you look at old "how to win" type books, you'll see authors who use this strategy.
With Millipede, there is a random regeneration of the mushrooms, and therefore there is no way to use these type of strategies. It's basically a vertical shooter where the 'pedes come faster and faster.
I find Millipede more fun since there's more variety. But for those who like to memorize Ms. Pac-Man levels, Centipede may be the better game.
Mario
shilmover
« Reply #7 on: December 11, 2007, 12:59:53 am »
Mario
Mario... Thanks!!!  that is a great explanation of the differences.
Just got the go ahead from the wife (she is truly great!!) to get it, so assuming it all checks out in person, I will pick it up.   :applaud:
My projects...
