Author Topic: Guncon2 Lightgun idea  (Read 5459 times)
zelony
  • Last login:November 16, 2019, 04:00:12 pm
    • Green Chavez Law Firm
« on: November 30, 2007, 10:52:02 pm »
I have been reading through a lot of the posts about Lightguns recently and had an idea.
I currently have a ActLabs Dual GS setup that only works with 98/ME and a set of LCD Topguns.  I love the look of the ActLabs guns, but since I upgraded to a Athlon64 X2 4200+ for my MAME cabinet, running Windows98 isn't on the menu.  So that leaves me with the just the LCD Topguns.
That would be OK, except I don't like how far back I have to stand with them.  Plus I don't like the look of them.
So, I was reading about the Guncon2 options.  I am using a 36" SVGA PC monitor in my showcase cabinet, so I would need to use some kind of converter to make it work.
That is when it occured to me, maybe I can cheat.  My video card can output direct to TV via S-video, Composite or Component.  So why not use the composite out to drive the Guncon2 guns?  If I set the Monitor to 640X480 and cloned it to the TV out, it should send the same signal to both.
I haven't tried it yet, since I have been too busy working. (Last time I fire an employee without having a replacement lined up :angry:)
Just thought I would throw the idea out there for everyone to bask in its glory or tear it apart.
Jeff
zelony
Re: Guncon2 Lightgun idea
« Reply #1 on: December 01, 2007, 04:02:12 pm »
Update:
I have my new computer for my MAME cabinet ready to go.  I am using a Radeon 9600SE with the S-Video to composite adapter.  I have it set to clone the primary display on the TV out.  I have tested it and it works fine.
I am going to swing by the used gaming store here in Des Moines and pick up a Guncon2 gun.  I plan to test my theory tomorrow, since I have to work until 2 AM again.   :angry: (Worst part of owning a business is the employees.)
I will let everyone know how it works as soon as I can.  Even if I fail miserably.  ;D
No big loss if I do, since I can use the gun on the PS2.
Later,
Jeff
« Reply #2 on: December 01, 2007, 06:22:43 pm »
Jeff,
You mention you have a 36" showcase cabinet.  Any chance you built it with a Gateway Destination monitor?  I am getting ready to start on mine and am struggling a little with how to design a cab for a monitor that big.
I am from Des Moines as well.
Tim
zelony
« Reply #3 on: December 01, 2007, 10:20:33 pm »
Tim,
Yes, it is a Gateway Destination.  However, I did not build the cabinet.  I purchased a NFL Blitz '99 Showcase cabinet in almost new condition and converted it. Like the one pictured here.  http://www.klov.com/game_detail.php?game_id=8819
I am using the 49 Way joysticks and love them.  So quiet and smooth.
I would have used the Monitor that came with the cabinet, however at the time there was no easy way to output 25 KHz from my video card.  So I bought the Destination.  Now I can use Soft 15KHz to output 25KHz from the computer to the Arcade Monitor.  Figures.
Now I have a spare 36" monitor taking up space in my office. hehe
zelony
« Reply #4 on: December 04, 2007, 05:17:09 pm »
I was unable to find a Guncon2 controller locally, so I had to buy one online.  I will let you know if it works when I get to it.  I am unfortunately still working a ton of extra hours since I am down a couple of employees... Anyone want to buy a PC Gaming Center and Internet Cafe in West Des Moines, IA?? :cry:
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« Reply #5 on: December 04, 2007, 05:51:05 pm »
is the Gateway a multisync?  will it do 15khz?  if so then run the Guncon2 of the sync of the monitor.. I have serious doubts that using the sync off the s-video will work.  The images will be cloned but I doubt the rasters will be in sync...  Good luck though!
zelony
« Reply #6 on: December 04, 2007, 06:39:12 pm »
No, the gateway is a standard SVGA monitor.  I figured it doesn't hurt to try.  No else has tried that I know of.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #7 on: December 04, 2007, 07:37:23 pm »
Sorry to be off topic...
Zelony, is that "CLICKS" image the logo of your place?  It's pretty cool, if so.
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
zelony
« Reply #8 on: December 04, 2007, 07:45:55 pm »
Yes, that is "Sir Fragsalot".  In the Original logo he was holding a mug of beer, but since we moved to the mall and no longer sell alcohol, I changed the logo.
I am glad you like it.
ZeroPoint
  • Last login:June 19, 2014, 08:07:07 pm
« Reply #9 on: December 04, 2007, 08:47:29 pm »
Zelony
I am sorry to be the (2nd) one to dissapoint you on your theory. The tv-out output and the vga ouput are not in sync. You must use the same sync signal for the gun that the monitor uses.
To get a GunCon2 working on a 31Khz+ monitor you will at least have to make a composite sync signal to feed to the gun. You will probably have to divide the h-sync also. Real Lightguns for CRTs doesn´t work where the phosporos isn´t charged (dark areas) and needs a flashing (one or two frames of white or grey) of the screen.
This time I would vote for the Act-Labs guns.
zelony
« Reply #10 on: December 04, 2007, 08:51:49 pm »
Zeropoint,
I figured as much, but why not try it. hehe
I would use the Act Lab guns if they would work with XP.
Maybe I can take the guts out of my LCD TopGuns and put into one of these.
At least then it would match my Arcade.
Pops
  • Last login:April 22, 2010, 10:33:43 am
« Reply #11 on: December 05, 2007, 05:48:03 am »
Zeropoint,
If that works, you gota get some flashing LED's in their as well ;D
I used to love them flint spark guns when I was a nipper..
