Author Topic: If using oil based paint, should I bother priming MDF?  (Read 1530 times)
Otto
  • Last login:January 30, 2008, 06:04:46 pm
« on: November 30, 2007, 03:50:40 pm »
I painting my cabinet black with the oil-based Rustoleum paint (not spray paint, going to roll it on).
I know I should prime if using latex paint on MDF, but not using latex. I have a can of Killz but it is white. Should I bother priming with that? I'm worried if I knick the cabinet or something, and there is white primer underneath, it may show through.
  • Last login:June 29, 2026, 03:23:15 pm
Re: If using oil based paint, should I bother priming MDF?
« Reply #1 on: November 30, 2007, 04:03:31 pm »
I don't know if you HAVE to but I always prime MDF before painting it.  If you are worried about color, just add a bit of the top coat color to the white primer to darken it so it will be less likely to show through if you nick it.
TOK
  • Last login:July 01, 2026, 03:41:31 pm
  • The Game Always Wins
« Reply #2 on: November 30, 2007, 10:10:32 pm »
I would prime it simply because the MDF absorbs a lot of paint in the first coat. I primed and painted a cab with the white Kilz and black Rustoleum oil based Satin Black using a foam roller. It is very tough when dry, and gives a great realistic arcade cab finish.
