Author Topic: 3" High Lip White Happs Trackball $69.99 untill 31st May  (Read 2217 times)
Zeitgeist
  • Last login:June 05, 2013, 05:57:51 pm
« on: May 10, 2003, 10:23:24 pm »
Just noticed that the new improved "red board" type 3" high lip trackball for use with Golden Tee are still sale priced at $69.99 each untill the end of the month!
This price is good for the white ball version only.
Also the ever popular horzontal microswith push buttons are .99 cents each.
Hope this info may help someone.
Z :D
There is a theory which states that if ever anyone discovers what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:3" High Lip White Happs Trackball $69.99 untill 31st May
« Reply #1 on: May 12, 2003, 02:20:02 am »
Z :D
So the "high lip" is not the same as the "high ball" trackball?  Was this the same one that was on sale last month?
Zeitgeist
« Reply #2 on: May 13, 2003, 10:07:34 pm »
I believe that it is.
Homebrew
  • Last login:May 03, 2012, 09:48:55 pm
« Reply #3 on: May 13, 2003, 10:13:08 pm »
No they are 2 different TB's.  The Highlip is essentially the regular TB with a 1/8" taller lip.  It allows the trackball to sit correctly when using plexi on top of your control panel.  With the highball TB, the ball sits higher than in either the regular or highlip TB.  Essentially with the Highball, more of the ball is exposed.  Hope this helps.
-Kevin
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: May 15, 2003, 12:45:34 am »
1) high lip is not same as high ball.
2) high lip was one sale last month, and still is on sale this month.
Robin
Knowledge is Power
Zeitgeist
« Reply #5 on: May 15, 2003, 11:51:05 pm »
Yup!
what he said...
vitaflo
  • Last login:January 14, 2020, 08:11:04 pm
    • ASMBLR
« Reply #6 on: May 18, 2003, 07:53:07 pm »
I actually went ahead and got this deal, both on the buttons and the trackball (which was the exact one I wanted anyway).  Saved myself almost $40 on the order.  :D
