Author Topic: Noob questions  (Read 963 times)
shanea
  • Last login:February 03, 2015, 06:29:36 pm
Noob questions
« on: November 24, 2007, 12:08:45 pm »
I have been bitten by the arcade bug. I have a modded xbox that is already running mameox and want to build an upright from scratch. Primarly for playing Space Invaders, Galaxian and such like
1. Is it best to use a TV or a PC monitor, and what size would be best
2. Should I go with an X-arcade and xbox adaptor or Joysticks and buttons with an Ipac and xbox adaptor
D4RKSL4Y3R
  • Last login:February 22, 2009, 01:12:33 pm
Re: Noob questions
« Reply #1 on: November 24, 2007, 01:45:58 pm »
the x-arcade is a bit low qultiy, look up arcade in abow i think its called- much better qulity and they let u customise it
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
Re: Noob questions
« Reply #2 on: November 24, 2007, 02:37:42 pm »
I have used the x-arcade encoder with an xbox.
It worked alright, but I had to modify the wiring harness since it
could not reach all of the microswitches on my cp.
Rebuilding that harness really sucked, so I wouldn't recomend it.
I also used a t.v. with an s-video connection, but the image quallity was
less than desireable, so I wouldn't recomend using a t.v. unless it has
component input and using the scanline filter in mameox.
Here is the the result.
If you plan on using a pc monitor, you may need somthing like the XCM 1080p converter
which will convert the component signal into VGA, however, if you're monitor can "sync on green"
all you have to do is hack a cable.
In the end, I wasn't satisfied with the picture quallity I was getting so I gutted it and
am now converting it into a 1-slot neo geo cab.
« Last Edit: November 24, 2007, 02:39:29 pm by gimp_hand »
Trample the weak, hurdle the dead
