Author Topic: DIY Control Panel help required !  (Read 1461 times)
maxmix
  • Last login:September 27, 2016, 07:07:14 am
    • Phoneking.co.uk
« on: November 22, 2007, 07:02:14 pm »
Hi Guys :)
I want to print (as a test) onto either a thin laminate or acetate sheet (For Inkjet printers) I have a lot of CP / Marquee art in vector format....
This then would be covered by a thin sheet of clear Lexan / Plexi etc
What would you recomend me to print onto.... Also thinking of this for a Marquee (Which may be illuminated).....
maxmix
maxmix
    • Phoneking.co.uk
Re: DIY Control Panel help required !
« Reply #1 on: November 23, 2007, 06:07:21 pm »
No ideas.... ? I wonder how the vector graphics would look on photo gloss card then put under 5mm of clear lexan etc ?
What do you think ?
maxmix
DaveMMR
« Reply #2 on: November 23, 2007, 06:23:41 pm »
For it to look best, you may want to check one of the vendors for custom printing of your artwork as it will be much better than inkjet printing - regardless of the paper.  I got my stuff printed at mamemarquees.com and they did an excellent job.
If you want to just do a test print, just print on regular paper with low quality.  Why waste the ink and paper on something you're going to be tossing?
