Author Topic: 256 line vertical resolutions  (Read 1711 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: November 20, 2007, 12:03:28 pm »
I noticed that both the ArcadeVGA and Soft-15Khz offer video modes with 256 vertical resolution at 60Hz refresh rate as part of their 15kHz video modes.
Is that not too high for a CGA montior?
265 X 60 / 15720 = 97.7% active lines which only leaves room for 6 blanking lines.
Older games that used a 256 vertical resolution like Kung-Fu Master, lowered the refresh rate to 55Hz to compensate for the higher number of lines.  Besides, you would want to run such a game at its original refresh rate since it scrolls so I wonder why this in not one of the built-in video modes in Soft-15kHz and the AVGA.
"The Manuel"
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
Re: 256 line vertical resolutions
« Reply #1 on: November 22, 2007, 02:16:14 pm »
You are correct, if these modes really are 60Hz you can't display them on a 15KHz monitor.
I assume most people don't use these modes anyway since they have their monitors adjusted to display 240/480 lines.
TheManuel
« Reply #2 on: November 22, 2007, 05:44:09 pm »
Thanks.
"The Manuel"
SailorSat
  • Last login:March 26, 2026, 10:41:24 pm
    • For Amusement Only e.V.
« Reply #3 on: November 27, 2007, 01:47:28 am »
They don't have 60Hz, the only show to windows with 60Hz.
Actually the output lower rates.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
