Author Topic: VB Developers question  (Read 1884 times)
danpomeroy
  • Last login:November 20, 2007, 12:41:40 pm
« on: November 19, 2007, 05:44:23 pm »
I can shell out to MAME but when I add the rom name it won't load. With no rom name, mame loads but says there are no roms even though there is. Any Ideas?
VB2005
SGT
  • Last login:March 04, 2026, 07:39:32 pm
Re: VB Developers question
« Reply #1 on: November 19, 2007, 06:34:48 pm »
Its a working directory problem.  Before shelling out, use CHDRIVE and CHDIR to the directory where mame is located.   That way, MAME can find the MAME.INI file (if it exists) and the ROMS folder.
Code: [Select]
    ChDrive ("e:")
    ChDir ("\emulators\mame")
    Shell ("mame.exe pacman")
headkaze
  • Last login:May 01, 2026, 04:33:46 pm
  • 0x2b|~0x2b?
« Reply #2 on: November 19, 2007, 07:03:28 pm »
This is VB 2005 though. So you really want to use the System.Diagnostics.Process namespace.
Code: [Select]
Private Sub LaunchGame(ByVal GameName As String)
   Dim myProcess As Process = New Process
   AddHandler myProcess.Exited, AddressOf MameExited
   myProcess.StartInfo.WorkingDirectory = "E:\Emulators\Mame"
   myProcess.StartInfo.FileName = "E:\Emulators\Mame\Mame.exe"
   myProcess.StartInfo.Arguments = GameName
   myProcess.StartInfo.CreateNoWindow = True
   myProcess.StartInfo.WindowStyle = ProcessWindowStyle.Hidden
   myProcess.EnableRaisingEvents = True
   myProcess.Start()
End Sub
Private Sub MameExited(ByVal sender As Object, ByVal e As System.EventArgs)
   MessageBox.Show("Mame exited!")
End Sub
SGT
« Reply #3 on: November 19, 2007, 07:43:08 pm »
What is the advantage?
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: November 19, 2007, 08:46:26 pm »
No great advantage, but Process is a handy namespace to get used to working with. It can tell you when a process has exited and hide the Command Line window for example. It gives you more control over the legacy Shell() method from VB6. It's really just the standard way to launch a process using VB.NET, but you get the same result in the end I guess ;)
