Author Topic: Jamma edge cconnector problems  (Read 975 times)
g.robert
  • Last login:September 05, 2015, 12:35:59 pm
« on: November 19, 2007, 03:44:09 pm »
I want to purchase from Bob Roberts a Jamma edge card connector with pins ASAP. I have a converted (from killer instinct) area 51 site 4. It frequently re-starts sometimes sticking in a continuous shut down / re-start mode. It seems when I wiggle the Jamma edge card connector the problem goes away for a few hours to days. I believe this is due to a loss of the +5VDC at that connection. Am I on the right track?
Thanks, Robert
SirPeale
  • Green Mountain Man
Re: Jamma edge cconnector problems
« Reply #1 on: November 19, 2007, 04:36:52 pm »
Sounds like it.  You could just tighten up the connection and clean the pins so it makes better contact.
g.robert
« Reply #2 on: November 20, 2007, 01:32:55 pm »
Thanks, I'll give it a shot.
Thanks, Robert
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #3 on: November 21, 2007, 12:14:41 am »
If the cleaning doesn't work, try putting a bead of solder on the pin on the board.  This will cause the connector to go in a bit tighter and make a better connection.
