Author Topic: wiring for arcade cabinet  (Read 3241 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: November 17, 2007, 09:55:47 pm »
So are you guys ordering online wires for the cabinet or going to your local home depot to get some wiring?
What kind of wiring should I use?
Icantlogin
  • Last login:December 01, 2007, 11:23:06 am
Re: wiring for arcade cabinet
« Reply #1 on: November 17, 2007, 10:18:33 pm »
This is a good read for wiring cabs. Hope it helps.
http://www.therealbobroberts.net/acwiring.html
I also usually buy my wire from him since I always have a parts order  for the project anyway.
Zeno
  • Last login:May 12, 2009, 11:22:33 pm
  • Movement is an illusion
« Reply #2 on: November 18, 2007, 05:16:22 pm »
Just go to Lowe's or Home Depot and buy some wire.  The size we use for our machines is dirt cheap.  Don't overspend online.
Zeno
Running: MAME
Projects: MK3, Ms. Pacman
BORIStheBLADE
« Reply #3 on: November 18, 2007, 05:35:31 pm »
what gage should I be looking for? 18? 22?
thanks
Rocky
« Reply #4 on: November 18, 2007, 09:06:04 pm »
For switches and joysticks 22 gauge is fine.
BobA
  • What Me Worry?
« Reply #5 on: November 18, 2007, 09:34:07 pm »
If you are wiring for an arcade pc board that is jamma compatible then your best bet is to buy a jamma harness.   That way you will have lots of cclor coded and sometimes labeled wire (depends on what you buy) that you can install in your cab.   This saves you the time and effort of recreating a jamma harness from individual wires.  Bob Roberts sells harnesses and connectors.
You will also have multiple power wires to safely carry the requred power from the PS to the jamma board.
