Author Topic: Setting up 2 mame 1 vertical | 1 horizontal (which front end to Use??.)  (Read 1255 times)
hayabusa_fmw
  • [Provisionally returned]
  • Last login:December 30, 2014, 03:24:56 pm
I decided to build 2 mame machines.
1 dedicated to Vertical games
1 dedicated to Horizontal games
Both system will run on a J-pac & arcadevga card.
the Front ends needs to be able to Take both(i don't know if it's a big issue:P)
Main question:
Wich Front end should i use....?
I would of liked to use the same one for both Pc's
I was thinking Atomicfe....
I have a few question
can you add mutiple emulators in Atomicfe? if yes how? can i make that
it seems quite Complicated...
if you have other ''better Fe i should use instead of Atomic shoot!'
I will try it..
I want something that is user friendly
thanks!
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Re: Setting up 2 mame 1 vertical | 1 horizontal (which front end to Use??.)
« Reply #1 on: November 15, 2007, 05:55:47 pm »
mala or atomic would be fine. both are really easy to set up.
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
« Reply #2 on: November 15, 2007, 08:05:46 pm »
Mala
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
