Author Topic: Electrohome G07 monitor question?  (Read 2561 times)
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« on: May 08, 2003, 07:59:45 pm »
Just got an arcade monitor, think it's a Electrohome G07?  Anyway, the monitor works just the picture is squished down to about 3 inches wide down the middle of the screen and I can't adjust it.  The monitor is mounted Vertically and its already been recapped by the previous owner.  So, from reading a lot of  message boards, it sounds like a Vertical Deflection transistor problem, but I'm just guessing?  Does this sound correct and if so, is this a hard or expensive problem to fix?
« Last Edit: May 08, 2003, 08:01:58 pm by creatine28 »
creatine28
Re:Electrohome G07 monitor question?
« Reply #1 on: June 06, 2003, 06:34:27 pm »
Just wanted to repost this incase someone migth be able to help?
paigeoliver
  • Awesome face!
« Reply #2 on: June 07, 2003, 11:11:32 am »
transistors are cheap and easy. I replaced the vertical output transistors on one of my monitors. I just unsoldered them, took one to the tv shop and picked up a couple of replacements (like $4 each).
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 29, 2003, 11:31:06 am »
Yeh, you may want to replace the vertical output transistors if you have already done a cap kit.
