Author Topic: Three Nintendo monitors, three Nintendo problems  (Read 1915 times)
More Cowbell
  • That's just dumb!
« on: November 12, 2007, 10:30:39 am »
I have a Popeye that I'm trying to restore and I have three monitors with which to do it.
Monitor 1) Came in the cabinet, dull colors, blotchy. Took it out, adjusted colors and brightness, all of a sudden it looks crisp and beautiful (not necessarily due to my adjustements). I put it back in, dull colors, blotchy. Looks like it needs to be degaussed. Do the degaussers go bad and sometimes correct themselves? Would a cap kit help?
Monitor 2) Nice colors, top 3" smear to the right (horizonatally). Did a cap kit, no change. Any ideas? Any other caps I didn't replace perhaps causing this?
Monitor 3) Beautiful colors, slight burn in from Dr. Mario but looks fine behind smoked plexi and when running game. Top 1/2" smeared (scores). Tried adjustments. Will a cap kit fix this?
I've got a fever...
grantspain
Re: Three Nintendo monitors, three Nintendo problems
« Reply #1 on: November 12, 2007, 12:28:02 pm »
the ptc components can go open circuit thus not operating the degauss coil
as for your others it does sound like caps or adjustments.
More Cowbell
  • That's just dumb!
« Reply #2 on: November 12, 2007, 12:35:28 pm »
Is there a way to fix the degaussing coil?
I've got a fever...
grantspain
« Reply #3 on: November 12, 2007, 12:43:21 pm »
you can try replacing the ptc component,may do the trick otherwise buy a degaussing wand as they are always helpful
ncflagg
  • Last login:October 25, 2025, 08:49:13 pm
  • Oh, yeah. Idaho IS right next to Iowa.
« Reply #4 on: November 12, 2007, 12:43:51 pm »
I have spent hours working on a few monitors that ended up being video connector problems. The monitor looked great one minute and then was missing colors/dark/hazy the next time I turned it on. Sometimes the punch-downs to the connector work loose or the pins get pushed back.
cw
  • Last login:March 26, 2026, 09:24:03 pm
  • Game over man game over
    • The Cab
« Reply #5 on: November 12, 2007, 02:54:54 pm »
thats one good reason to reflow the input pins and to double check your harness for damage or corrosion on the pins....
SavannahLion
« Reply #6 on: November 12, 2007, 08:48:02 pm »
PTC?
Kevin Mullins
    • Me on Myspace
« Reply #7 on: November 12, 2007, 09:58:35 pm »
PTC
Generally the round disc looking component you will find near the plug in on the main chassis for the degauss coil. They can also be found contained in a small square box. Without getting technical about this, it acts as a switch based on the current flow and tewmperature change due to that current flow.
It is ON when cold, OFF when hot.
« Last Edit: November 12, 2007, 10:00:13 pm by Kevin Mullins »
