Author Topic: arrows that go under the joysticks  (Read 1708 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: November 10, 2007, 07:27:10 pm »
So I'm slowly plugging away with my CP and need some nice arrows. I know I don't need them but I would like to put them under the joystick.
Are there any templates or is this something that you do in photoshop on your own?
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: arrows that go under the joysticks
« Reply #1 on: November 10, 2007, 11:42:42 pm »
Not that i'm the arrow expert, but I ended up making mine using the vector tools in photoshop.
1.  Create a crosshair representing the center of the joystick
2.  Create your first arrow (let's say up)
3.  Duplicated the layer, make sure that layer is active
4.  Activeate the transform tool (control+t)
5.  Move the pivot to the center you marked for the joystick by dragging the center crosshair
6.  Now place the cursor at the top right corner of the selection box (it should turn into a rounded arrow)
7.  Hold shift and right click, drag down and right to rotate it by snapping to 45's
8.  Repeat from step 2 until you have complete arrow artwork.
Hope that helps.
-csa
