Author Topic: Cracked tube?  (Read 1703 times)
SavannahLion
Cracked tube?
« on: November 09, 2007, 11:32:33 pm »
Even after carefully examining the tube, I have no idea if the tube actually works. (Wells Gardner K7191)
Since I currently have no working PCB to test with, is there any other way to at least get a basic idea if the tube in question has been gassed out or if it's something worth testing?
SirPeale
  • Green Mountain Man
Re: Cracked tube?
« Reply #1 on: November 10, 2007, 07:13:10 am »
Only if you have access to a rejuvinator.
SavannahLion
Re: Cracked tube?
« Reply #2 on: November 10, 2007, 11:29:51 am »
So to even find out if a tube is worth salvaging, I'd have to have a working PCB or a rejuvenator. Great.  :banghead:
Oh well... maybe I can cannabilize the two non-working PCB's I do have and make one working board before I start ordering parts.
FrizzleFried
    • Idaho Garagecade
Re: Cracked tube?
« Reply #3 on: November 10, 2007, 01:07:53 pm »
Fire it up and turn up the screen pot...see if it even lights up.
SavannahLion
Re: Cracked tube?
« Reply #4 on: November 10, 2007, 08:32:22 pm »
I did fire it up. The flyback popped. The other is missing a daughter board that I need to remove from the other. IOW, I need to rebuild at least one board somehow.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Cracked tube?
« Reply #5 on: November 13, 2007, 11:13:04 pm »
most vacuum tubes have a visible silver looking material called a "getter" inside the glass envelope.
this material will change (color) to a white powder when exposed to air .
 also if vacuum is lost , the "heater" filament should burn out upon applying power and
there would likely be arcing inside the gun assy' when high voltage applied .
typical 2nd anode is around 30kv for a 25"+  crt
qrz
