Author Topic: Transistor equivalent cross reference database  (Read 6023 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« on: November 06, 2007, 04:00:03 pm »
For you techs out there.
What’s your favorite site for replacement part cross referencing ?
Kevin Mullins
    • Me on Myspace
Re: Transistor equivalent cross reference database
« Reply #1 on: November 06, 2007, 04:04:55 pm »
I usually take a poke at it here (NTE Cross Reference) first since most places carry the NTE equivelants anyways.
And if it finds a match there's usually a datasheet to go with the information as well.
Arm123
« Reply #2 on: November 06, 2007, 04:34:29 pm »
yup..  i stumbled across them from google.  Very first match for 'Transistor Cross Reference'
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #3 on: November 13, 2007, 11:29:55 pm »
it is best to use orig numbers whenever possible .
if orig is nla, select a sub that is equal or greater than the original specs...
there is also the rare occasion that only the original device will work in a perticular circuit.
a couple of spec sites i use:
www.alldatasheet.com
www.datasheet4u.com
and there are more out there  !
generaly , sk/ nte's ( etc.. ) are more $ than originals
qrz
