Author Topic: Lazarus Skinner Error. I'm grateful for any help.  (Read 2236 times)
Nikodemz
  • Last login:May 11, 2003, 05:25:37 pm
« on: May 07, 2003, 11:54:51 am »
While trying to use the "advanced" options in the Lazarus Skinner 2.5, I continually get a run-time error '339' "component tabctl32.ocx or one of it's dependencies is not registered correctly: a file is missing or invalid."
Has anyone else encountered this problem. Everything else works just fine I just can't access the advance tab.
I'm running Windows XP if that has any relevance.
Thanks in advance for any suggestions or solutions.
-Will
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
Re:Lazarus Skinner Error. I'm grateful for any help.
« Reply #1 on: May 07, 2003, 12:43:36 pm »
The tabctl32.ocx is not registered correctly on your system. Do a Start->Search->Files or folders, and look for tabctl32.ocx. Once you've found it, double click on it. Then a dialog should appear asking you what program to open it with. Click "other" and go to your c:\windows\system32 directory, find the file regsvr32.exe, and click on it. Click "ok", and a message box should appear saying that the control was successfully registered.
Re-rerun laz Skinner and check it out.
-PacManFan
-Will
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
« Reply #2 on: May 07, 2003, 06:38:06 pm »
If it's not there let me know and I'll send it to you.  Should be with the vb runtime files though.
thanks pmf...
Nikodemz
« Reply #3 on: May 09, 2003, 04:19:32 pm »
i could not find the file on my computer.   :'(
It would be great if you could send me the file. I'd like to see how else I can play with my Skins. If i get things worked out the way I want I'll post links to them so other folks can check them out and maybe use them for their own projects.
Thanks.
-Will
(Howard, I dropped you a personal message on this board but I don't know if it went through. Thanks for all your help.)
