Author Topic: Modular Control panel latch  (Read 1450 times)
nussmier
  • Last login:November 06, 2018, 08:03:23 pm
« on: October 30, 2007, 12:06:00 pm »
I have been doing some research to start converting my control panel to a modular design.  I have seen Doc's modular panel and I like it.  I have read that some people like to add another way to secure it in the vertical plane just to be safe.  I tend to be pretty aggressive so I was thinking I would want it to be more secure.  I was wondering has anyone tried to use those child proof locks that are magnetic?  Are they tight latching to ensure no play?  Are they strong enough et etc.  I was thinking I would mount a latch under every dowel that is in the panel.
Nuss
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Modular Control panel latch
« Reply #1 on: October 30, 2007, 12:47:58 pm »
...I was wondering has anyone tried to use those child proof locks that are magnetic?  Are they tight latching to ensure no play?  Are they strong enough et etc.  I was thinking I would mount a latch under every dowel that is in the panel.
Yes
Not really if you want it to latch/unlatch without having to bend the CP (it needs to swing freely, but 1/32" is enough IIRC)
Yes (with one of these + guides I can lift my box CP by either joystick without the bottom falling off)
edit: I used these "Magnetic Tot Loks".
« Last Edit: October 30, 2007, 12:50:58 pm by u_rebelscum »
Robin
Knowledge is Power
SavannahLion
« Reply #2 on: October 30, 2007, 02:10:44 pm »
Oh wow, I didn't even know those things existed. And here I was trying to figure out how I could do the same thing from scratch.
telengard
  • Last login:April 28, 2026, 11:37:11 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #3 on: November 02, 2007, 12:13:25 am »
Nuss
Yeah, I'm also aggressive and I lock my modular panels down w/ screws.  I knew that if they felt even remotely like they might give or something and get loose it would alter my playing.  I have absolutely *zero* issues with aggressive play and I'm probably the sloppiest Robotron player out there.   :)
Good luck with your project!  If you are looking for a different approach I've documented how I did mine (see signature).
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
nussmier
« Reply #4 on: November 02, 2007, 06:57:46 pm »
Yea I checked yours out Tel its pretty sweet just not sure I want to go that route yet.  Who knows one day I might end up there anway..Thanks for the input...
