Author Topic: need help with soldering to gamepad!  (Read 1755 times)
D4RKSL4Y3R
  • Last login:February 22, 2009, 01:12:33 pm
« on: October 28, 2007, 07:31:11 am »
hi, iam making a arcade stick for my xbox 360, iam onto the soldering of the PCB but i cant get the solder to stick. i have herd that you have to scrap away the rubber from the solder points- is this true? also does any one have any tips for soldering onto PCbs?
i have attached a pic of the solder points
thanks
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
Re: need help with soldering to gamepad!
« Reply #1 on: October 28, 2007, 10:17:02 am »
Its easy to like someone,
If you dont know them very well.
D4RKSL4Y3R
« Reply #2 on: October 28, 2007, 11:14:22 am »
thanks|!
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: October 28, 2007, 11:29:31 am »
You need to carefully scrape off the black stuff until you see shiny copper.  Then clean the area with rubbing alcohol.
You can use a wire wheel on you dremel or very carefully,  a tiny flat head screw driver.
