Author Topic: Arcade Cabinet, Sound stays on ?  (Read 2139 times)
vertygo
  • Last login:September 20, 2015, 03:19:59 pm
« on: October 19, 2007, 07:43:26 pm »
I have a Meta Fox standup arcade machine, and when I power it off, the sounds keeps playing. Odd.
Screen turns off just fine, everything else working a-ok.
any thoughts for a non-electrician type ?
Kevin Mullins
    • Me on Myspace
Re: Arcade Cabinet, Sound stays on ?
« Reply #1 on: October 22, 2007, 09:25:22 am »
I'd bet you can still "play" the game as well when you "turn it off".
Sounds to me like the game pcb power supply is not tied into the power switch.
vertygo
« Reply #2 on: October 22, 2007, 12:24:40 pm »
I thought so too, however, if you click the power switch a few times, or wait awhile, it does eventually shut off completely.  :dunno
Kevin Mullins
    • Me on Myspace
« Reply #3 on: October 22, 2007, 01:08:26 pm »
You may just have a bad switch then.
vertygo
« Reply #4 on: October 22, 2007, 01:15:07 pm »
Is that the case, even tho the monitor powers off right away ?
