Author Topic: ATOMICFE screen cut on the right  (Read 1467 times)
corrupt27
  • Last login:December 17, 2021, 09:46:35 am
« on: October 18, 2007, 11:18:27 pm »
Hey guys,
 I have started to use ATOMICFE i love it but i have been having an issue where the right side of the screen is to large. Meaning that the right side gets cut off.  The main menu screen and when running mame.
But if i run mame from the command prompt i dont have this issue. Does anyone have any ideas?
Thanks guys
corrupt27
Re: ATOMICFE screen cut on the right
« Reply #1 on: October 19, 2007, 12:03:31 am »
OH YEAH
I am using the standard vga with a 19inch monitor.
Thanks guys
corrupt27
« Reply #2 on: October 19, 2007, 12:43:34 am »
OK I also tested mamewah and the same issue.
When i start the arcade game ex:baddudes  the right side is so far to the right it cuts off the screen.
This also happens in the menus.
But if i manually run c:\mame baddudes  it fits perfect.
Any ideas?
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #3 on: October 19, 2007, 03:58:51 am »
When you run manually , do you use exactly the same mame.exe that you reference from the FrontEnd?
Or Does the one you use with the FrontEnd is in another folder?
If they are different try to copy the Mame.ini file you have in the folder where you start manually to the folder where the mame used with the Front End is.
corrupt27
« Reply #4 on: October 19, 2007, 12:09:49 pm »
Thanks for the quick reply. It is pointing to the same mame. Also atmoicfe menus are  cutting off to the right of the screen. I have it on 2 different pcs and the i receive the same outcome.
Any ideas?
youki
    • Atomic Front End
« Reply #5 on: October 19, 2007, 12:14:57 pm »
What is your desktop resolution?
And in what resolution you choosed for Atomic?
What is your OS? XP or Win98?
corrupt27
« Reply #6 on: October 19, 2007, 07:48:59 pm »
I am using xp pro with resolution of 1280 x1024
and atomic is set to 640x480
corrupt27
« Reply #7 on: October 19, 2007, 07:51:50 pm »
that was it  :applaud: you ROCK
youki
    • Atomic Front End
« Reply #8 on: October 20, 2007, 06:02:16 am »
