Author Topic: Robotron Screen Measurements  (Read 2965 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: October 15, 2007, 01:57:19 pm »
Anyone with a real Robotron ever measured the box or borderline of the playing screen?  I want  to compare the to what I'm getting with native rez on a 27in TV.  Want to see how far off I am.  Playing with HW Strech on the 27 is too much.
tophatne1
  • Last login:January 09, 2016, 12:05:15 am
Re: Robotron Screen Measurements
« Reply #1 on: October 15, 2007, 02:41:21 pm »
I have an empty Roboton cab and I measured the max viewable area as 22.5" W x 17"H.
Don't know if that's the measurement you wanted, but that's what I got on a sheet of paper in my wallet just in case I come across a cheap big computer monitor for the empty cab I have.
« Last Edit: October 15, 2007, 02:43:41 pm by tophatne1 »
Chunce DeLeone
« Reply #2 on: October 15, 2007, 03:43:27 pm »
I appreciate the response but what I am looking for is a person with a working Robo, once its running... the box around the play area in the game itself,  the length and width of that.....
spacies
« Reply #3 on: October 15, 2007, 03:55:11 pm »
I have a Robotron arriving in a couple of days.
I will post something if someone hasn't done it before hand.
Clu
  • Last login:January 10, 2013, 12:34:22 am
  • Watch it, sucker.
« Reply #4 on: October 16, 2007, 12:26:06 am »
As close as I could tell, mine measured 15 x 10 3/4, outer edge to outer edge on the playfield box.  Some of the graphics on mine go slightly beyond the monitor shroud on the left and right (circles on the title screen) so I don't know if it was adjusted or not.
Chunce DeLeone
« Reply #5 on: October 16, 2007, 07:55:18 am »
Cool I'll check that,  if anyone gets something different or can confirm that please post.
Chunce DeLeone
« Reply #6 on: April 25, 2008, 09:33:41 am »
I know this post is old but i've been thinking about screen mearsurements,  I know that when you keep the aspect ratio in Mame you will get the resolution that the original game had with black borders around it.  Now does that mean that the actual dimensions, Length and width,  of the veiwable area is exactly the same size as the original.  to say it another way, if the actual dimensions of the robotron original arcade  playable area is 15 X 10 3/4 as generously reported by Clu, thank you, when I keep the aspect ratio on my 27inch tv, will it be 15 X 10 3/4?  Sorry if that isn't clear,
Spacejack
  • Last login:November 15, 2011, 02:47:16 am
« Reply #7 on: April 25, 2008, 07:32:48 pm »
I think that that would be the case, provided you're running at arcade monitor's max resolution (720x480? I don't really know)... you'd have to either turn off all stretching or double the size exactly, but I think that would produce a centered image that would be in the same spot it occupied on a heavily masked monitor.
paigeoliver
  • Awesome face!
« Reply #8 on: April 28, 2008, 12:38:01 am »
Talking about resolutions and such is way, way off for what you are talking about.
Robotron had a standard res 19" screen. It is a much harder game on a 27" monitor because it is harder to see everything at once.
Chunce DeLeone
« Reply #9 on: April 28, 2008, 11:15:25 am »
yeah, I don't want a fullscreen image, i just want the exact size screen that the original had,  my question is that can mame do that with certain setting no matter what size monitor you are using?
