Author Topic: MAME SETTINGS WITH LCD TOPGUN  (Read 3081 times)
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« on: October 04, 2007, 03:34:14 pm »
I've recently acquired two LCD Topguns with the intention of using them with MAME. I have installed the Gun2mouse driver3.2 intended for use with the gun, and have successfully calibrated it using the calibration tool it comes with. I have even used it as a mouse, so I know it works.
Tthe only thing is, I cant get it to work with MAME or MAME32. Does anyone know what flags I need to check in MAME.ini, or in the case of MAME32, which boxes to tick in the 'default game options'?
I have tried various settings, setting lightgun to 1 and mouse to 1 etc, but just can't get it to work. Does anyone have an .ini file I can copy? I am using MAME 0.118 or MAME32 0.119.
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
Re: MAME SETTINGS WITH LCD TOPGUN
« Reply #1 on: October 04, 2007, 07:32:29 pm »
You have to use SMOGS Guncon driver, the ems ones are crap. They will work flawless with smogs.
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« Reply #2 on: October 04, 2007, 08:55:02 pm »
Set the following in your mame ini.
lightgun 1
lightgun_device lightgun
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
Turnarcades
    • Turnarcades
« Reply #3 on: October 06, 2007, 06:19:23 am »
THE SMOGS DRIVER AND THE MODIFIED DRIVER BOTH WOULDN'T RECOGNISE THE GUNS AT ALL.
I DID REINSTALL THE NORMAL DRIVER, AND CHANGED THOSE SETTINGS IN MAME, BUT IT RECOGNISES THE GUNS WEIRD. FOR INSTANCE,PLAYER 1 TRIGGER IS  RECOGNISING AS 'NONE' WHEN I TRY TO RECONFIGURE IT, AND BY DEFAULT IT RECOGNISING THE MOVEMENT AS PLAYER 2'S CURSOR. ANY IDEAS?
SOMEONE MUST HAVE THESE WORKING............
mrserv0n
« Reply #4 on: October 06, 2007, 03:00:54 pm »
I don't see how Smogs gun2mouse drivers did not work for you, make sure you completely uninstall EMS's before installing smogs, after everythings uninstalled plug in your gun, windows will search for a driver, point it to the smog one and it will work, mame automatically loves the smog one and you won't have all those problems. Theres a tutorial somewhere in the 100 page forum about this gun from Sky or something that shows you exactly what to do. I went through hell originally with these guns, if you uninstall everything and plug in the gun and it finds a driver automatically then you didn't uninstall properly have to take that driver out of you pc wherever its hiding, just deleting the ems directory doesn't cut it if I remember right
« Last Edit: October 06, 2007, 03:03:04 pm by mrserv0n »
rdenis
  • Last login:January 11, 2011, 04:19:38 pm
« Reply #5 on: October 19, 2007, 03:23:19 am »
Can anyone confirm they are using their LCD Top Guns flawlessly in 119?  If so, what driver are you using?
mrserv0n
« Reply #6 on: October 19, 2007, 07:05:27 pm »
i confirm flawless use in 119 and 120, smogs driver
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
« Reply #7 on: October 20, 2007, 08:14:30 am »
Working perfect here: 2 (or 3) LCDTopGuns with Smog Drivers and WindowsXP.
rdenis
« Reply #8 on: October 20, 2007, 07:46:02 pm »
Thanks - loaded up Smog's driver and now working great with 119 and XP on a 28" LCD monitor.
