Author Topic: AAAHH, Help! (D9200 problem)  (Read 1895 times)
gamecaptor
  • Last login:October 15, 2004, 01:26:48 pm
« on: May 03, 2003, 04:45:43 am »
I recently bought a D9200 monitor (like 2 weeks ago) and all of the sudden the monitor stopped showing the red. So I adjusted the red contrast in the menu, but every time I changes screens (say start or exit a game) it defaults back to no red, so I have to manually adjust it back :( For your information, I
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:AAAHH, Help! (D9200 problem)
« Reply #1 on: May 03, 2003, 07:07:53 pm »
Make sure the monitor cable is plugged in all the way. If it is plugged in all the way, you should try another cabel with it. It sounds like you monitor isn't getting the red signal properly, and that's likely the cable.
gamecaptor
« Reply #2 on: May 03, 2003, 08:31:41 pm »
I've checked that, it's not the cable. It's the actual "red" setting in the menu options, it's turned all the way off. If I turn it up, it just goes back to nothing (i.e. turned off) when I change games/resolution/settings.
