Author Topic: What would you say are the dimensions of this thing?  (Read 1814 times)
The cranky hermit
  • Last login:June 03, 2006, 01:35:04 am
  • CP #1: Completed
TheTick
  • Last login:December 21, 2009, 12:24:27 pm
  • I.P. Daley
Re:What would you say are the dimensions of this thing?
« Reply #1 on: May 03, 2003, 12:14:35 am »
It's either 2 foot across, and 1 foot high....
or 3 foot across, and 1 1/2 foot hight.
I'm guessing closer to the second because of the nice spacing between the upper and lower controls. Mine is 2x1 and is a similar layout.
Mucal invader, is there no end to your oozing?!
TheTick
  • I.P. Daley
« Reply #2 on: May 03, 2003, 12:20:29 am »
Actually if that is a Happs 3" trackball and mounting plate, than the mounting plate should be 6" across and 6.5" high.
So maybe closer to 27" across. The aspect ratio is probably wrong on my screen so the height is probably less than 13.5".
I'm thinking 2'x1' was a pretty good guess.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: May 03, 2003, 07:45:47 am »
FWIW, Happs 3" mounting plate is 6.5" square (6" from center outer plate mounting hole to center outer plate mounting hole).
Going on that, I'm getting appox 30" across by 16" vertical.  Bottom horizontal edge ~14".  Bottom TB mounting plate ~3"-3.5" from bottom, center to center of a three button row ~3".
Robin
Knowledge is Power
