Author Topic: Can't sync "time crisis"  (Read 1918 times)
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« on: October 01, 2007, 04:17:01 am »
My MAME machine is a dedicated cabinet running an arcade VGA, Jpac and a brand new 15Khz monitor.
All the games I've played so far work fine, but tried to play Time Crisis and the vertical sync was out...adjusted that (played fine), then all the other games were out of sync.
Any thought??
Is this a known problem?
Thanks in advance
northerngames
  • Trade Count: (+18)
Re: Can't sync "time crisis"
« Reply #1 on: October 01, 2007, 01:26:10 pm »
turn the pot all the way to the left and adjust from there I just went through a similair situation
sega_mad
« Reply #2 on: October 01, 2007, 02:51:54 pm »
Tried that all ready......no joy!!
thanks anyway.
BUGGER
northerngames
« Reply #3 on: October 02, 2007, 01:06:30 am »
try manually adjusting the display size for time crisis to match the rest of the games maybe it is set for 800x600 when it needs to be set at 640x480 etc.
sega_mad
« Reply #4 on: October 02, 2007, 01:57:23 am »
Mala runs all my games at 640 X 480.
Is there another way to do this.....could you spell out what I need to check?
All though, not sure if that would fix it, it appears to be a sync/ vertical hold problem, not a resolution problem.....I could be wrong though, I'm no expert on these things!!
Cheers
