Author Topic: Increasing vertical deflection makes image shake  (Read 1314 times)
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
« on: September 28, 2007, 01:57:21 pm »
I've got an 8liners board question:
Scenario 1:
Tube impedance - 1.7ohm H, 10ohm V.  image is stable at full screen (640x480i, 320x288) etc
Scenario 2:
Same board, Tube impedance 1.7ohmH, 6.5ohm V.  Image is stable at 320x288, but is shakey at 640x480i.  If I reduce the vertical size to about 2/3 of the monitor, it is dead on clear.
So obviously, my vertical yoke impedance is affecting the full screen ability.   By adding a 1-2 ohm 10W resistor to the horizontal yoke circuit (in series as suggested by 8liners), will that in effect correct my shaking issue?  I realize the horizontal circuit does supply power to the whole coil.
Thanks,
S
