Author Topic: Move picture up on a DK [Sanyo EZ] monitor?  (Read 1654 times)
Neilyboy
  • Last login:September 04, 2026, 09:00:28 am
  • what day is it...
« on: September 22, 2007, 08:09:19 am »
Well I am finishing up my DK restore and finally got all the harness' and stuff needed to hook it up. I flipped the switch and woohoo I had jumpman and dk on the screen. Only problem is the picture seems to be an inch or so too far down. Nothing is cut off on the screen it just seems like it is down too far. I moved the V-Center knob all the way to the right which moved it up a bit but now its all the way to the right and I cannot move it anymore. Can the face of this pot be removed them turned back left and then put back on so I can spin it more to the right or no?
I am not all that familiar with monitor so any help is much appreciated.
Neil
Ken Layton
  • Guru
  • Technician
Re: Move picture up on a DK [Sanyo EZ] monitor?
« Reply #1 on: September 22, 2007, 12:52:39 pm »
Because this monitor has the tube mounted vertically, you need to adjust the "H Center" pot on the adjustment board. If that doesn't move it enough, there are two horiz and vertical centering pots on the Donkey Kong gameboard.
Neilyboy
  • what day is it...
« Reply #2 on: September 23, 2007, 05:13:37 pm »
Thanks Ken Ill look over the board since I have the HCenter pot on the monitor turned all the way up. You the man.. I figured there may be one on the game board too but havent looked it over enough to find it.. i saw one labeled like 30k and 50k i think.
Neil
