Author Topic: Degaussing crt - speakers placed on top of screen  (Read 2214 times)
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
« on: September 21, 2007, 03:07:54 pm »
My dad left a speaker against my arcade monitor while it was in storage in his shed
The right hand sides colout is a little funky, just a small patch about the size of a cigarette packet.
There is a Degaussing button on the monitor but its not fixing it, How difficult would it be to fix this if its even possible?
Cheers
Cathal
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
grantspain
Re: Degaussing crt - speakers placed on top of screen
« Reply #1 on: September 21, 2007, 05:12:21 pm »
switch off the power to the cab and wait 24hrs,if its still has the problem you may need to get it manually degaussed
CathalDublin
« Reply #2 on: September 21, 2007, 05:49:56 pm »
Can that be done yourself with a tool
like this?
eBay Link
« Last Edit: September 21, 2007, 08:13:20 pm by Peale »
grantspain
« Reply #3 on: September 21, 2007, 06:02:14 pm »
thats exactly the tool
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #4 on: September 21, 2007, 06:08:51 pm »
For sure.
Start with the hand degausser at the center of the screen (3" away), press the on button now move in a growing circular motion toward the outside edges of the screen.
Pull the degausser away from the screen with power on 3~5 feet until it has little/no effect on the screen.
Power off.
Fixed!!
Be careful do not put the coil down so that the pushbutton switch can accidentaly be left on - the coil will overheat and melt, could cause fire.
By the way, for others, this coil is 220 volt, not suitable for North America.
Good Luck
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« Reply #5 on: September 21, 2007, 06:19:20 pm »
btw, where are you located?
I have one (and others do also).... you might get lucky and find someone close with one.
the round one I have was about 30 bucks on ebay.
CathalDublin
« Reply #6 on: September 21, 2007, 08:46:02 pm »
Thanks guys
I'm in Ireland BTW, Dont think theres that many Irish members
Just moved machine out from the wall and its all fine now, when I move back, the right hand side go's all messed up, but theres no magnets anywhere??
Freaky >:D
SirPeale
  • Green Mountain Man
« Reply #7 on: September 21, 2007, 09:24:05 pm »
There is a magnet.  A rather large one.  The planet.  You'll need the degaussing wand to get the colors right after moving it.
CathalDublin
« Reply #8 on: September 22, 2007, 08:34:54 am »
The degaussing button fixes it once its moved
